Which Gears
Old Jan 8, 2005 | 02:19 PM
mcarota's Avatar
mcarota
Default Which Gears
I have a 98 Coupe A4. How can I tell what gears I have in it now, as I may be looking into an upgrade. Thank you in advance for any help.
Old Jan 8, 2005 | 05:51 PM
quick99ls1's Avatar
quick99ls1
if you have the code G92 in your glove compartment then you have the 3.15s but if you have GU2 then you have 2.73 hope this helps, let me know what you have
Old Jan 8, 2005 | 06:14 PM
mcarota's Avatar
mcarota
thanks for the info, i will check it out!!!!
Old Jan 8, 2005 | 06:57 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The RPO sticker is not in the glove box on the 98's like it is the newer models. It is on inside of the driver's rear cargo compartment cover.
The rest G92=3.15 is correct, unless someone before you has already changed it out......
Old Jan 8, 2005 | 08:04 PM
quick99ls1's Avatar
quick99ls1
thanks i was unaware that the 98 had them in a different location, i have a 99 thats why
Old Jan 8, 2005 | 08:37 PM
If it says G92 on your options tag, then you have the 3.15 gears. Otherwise, you have the 2.73 gears.
To Which Gears
