[Z06] K&N filter
Old Jan 9, 2005 | 04:43 PM
bit's Avatar
bit
Cruising
Default K&N filter
What are the dimensions of 02 Z06 filter? I guess $50 is not bad for the filter but I figured if I looked by size instead of for a Z06 filter I might find one cheaper.
Brent
Old Jan 9, 2005 | 05:11 PM
bud miller's Avatar
bud miller
96 camaro SS exactly same size and probably others...
Old Jan 9, 2005 | 05:29 PM
bit's Avatar
bit
Cruising
I was able to find the info on K&Ns site
33-2111 Product Specifications
Product Style: Panel Air Filter
Height: 1.125 in (29 mm)
Outside Length: 16 in (406 mm)
Outside Width: 8 in (203 mm)
Filter Re-Oiling Amount: 1.96 oz (58 ml)
Weight: 1.8 lb (0.8 kg)
Product Box Length: 17.13 in (435 mm)
Product Box Width: 8.25 in (210 mm)
Product Box Height: 1.75 in (44 mm)
for anyone that is interested
-Brent
Old Jan 9, 2005 | 08:30 PM
Snidley's Avatar
Snidley
I have one with about 3000 miles on it. I'll let it go for $35 shipped to you. I got a Halltech system to replace it.
Old Jan 9, 2005 | 08:33 PM
augydog's Avatar
augydog
St. Jude Donor '08-'09
Brent
I bought one and noticed it had a rubber gasket inclosed in the box with the filter.
I put the filter on without the rubber gasket, and it didn't seem to fit correctly, so I took it back off and put the stock filter on.
Apparently the rubber gasket is necessary to make a good seal. but, to put the gasket on you would need to remove the airbox, and I didn't want to remove it.
Aren't the K&N filters supposed to be the same size as the stock?
tia
augydog
To K&N filter
