Help - Column Lock Bypass Kit
Old Jan 11, 2005 | 02:15 AM
vtech's Avatar
vtech
Default Help - Column Lock Bypass Kit
I am new to Corvette Forum and just purchased a FRC Tourch Red 1999 vette from a Doctor in Newport Beach, CA with 30,000 miles. This car still smells new and the man hardly never used it. From reading all the Threads it seems like the 99 FRC is truley a nice design and becoming more popular - glad I scored. Well enough of that - just so excited about owning a C5 - should have bought one years ago. Still love my C3 Mulsanne Blue Coup - original 54,000 miles in mint condition - total different ride.
My question has to do with the Column Lock Bypass kit. After reading all these threads pertaining this problem I am convinced to take care of before a nightmare happens. Where do I go to purchase one and are they hard to put in or does a dealer have to do it. Also I assume the steering wheel nevers locks again - what does this actually do - please advice. Any installation advice.
Old Jan 11, 2005 | 03:34 AM
WWK888's Avatar
WWK888
You can check with Thunder Racing (supporting vendor listed to the left on the forum homepage). The following is a link for the install. It is very easy to do, maybe 15-30 minutes depending on your skill level.
http://www.ls1howto.com/index.php?article=24
Old Jan 11, 2005 | 03:42 AM
Cscokd's Avatar
Cscokd
http://www.ls1howto.com/index.php?ca...81c181d1d4369f
Old Jan 11, 2005 | 03:47 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Congrats and welcome. You may have received a recall notice about this "problem", but I'd go with the by-pass kit as mentioned. It's not too hard to install, but it did take me about an hour....but I took my time.
Old Jan 11, 2005 | 03:54 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
GREAT Advice!!!!
Old Jan 11, 2005 | 08:07 AM
Automag928's Avatar
Automag928
Yep get the bypass kit and don't think twice about it.
Old Jan 11, 2005 | 08:17 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Originally Posted by mph1972
GREAT Advice!!!!
Congrats on the FRC
Old Jan 11, 2005 | 08:37 AM
I got mine from Thunder Racing - fast service and a good price. It is not hard to put in - just follow the directions in the link mph1972 provided. That's the same source for the install I used.
Old Jan 11, 2005 | 09:02 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
How does a CLB work? The first part of the install is to use an adapter to retract the locking pin. Once this is done then you install the CLB which basically prevents any voltage from getting to the locking motor ever again, which keeps it in the retracted position. Simple!
Installation is not too hard - you do have to remove some interior panels, or at least open them up enough to fit the CLB in there and to make the necessary electical connections. I would guess that most people get them installed in an hour or so.
Old Jan 11, 2005 | 09:22 AM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
Old Jan 11, 2005 | 09:23 AM
USA-VET's Avatar
USA-VET
Old Jan 11, 2005 | 09:49 AM
COHMATT's Avatar
0COHMATT
Former Vendor
Corvettes of Houston, $49.95
800-829-6434 or 281-821-1222
To Help - Column Lock Bypass Kit
