competitive driving
Old Jan 12, 2005 | 05:11 PM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
I could be the one who is wrong. I don't use the Competitive Driving mode that often. I do know you can get rid of a current message and display normally by hitting reset. Good excuse to go play with my DIC.
Old Jan 12, 2005 | 05:14 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Naaahhhhh.......I'm 99% sure you've gotta hit the AH button again to get it out of Comp mode......
Old Jan 12, 2005 | 05:16 PM
timbo79's Avatar
timbo79
There is also a bypass unit that will put your car in comp driving every time you start it automatically, and the display will clear. I forget which vendor I got it through, but it is a good gadget, since on the 2000 model, at least, you have to be at a standstill to change to comp driving (but not to turn it off, go figure) Very easy to wire in, and also very easy to remove if you don't like it.
Old Jan 12, 2005 | 06:24 PM
Woodstoc's Avatar
Woodstoc
Does anyone know if Competitive mode or AH TC off removes all torque management from the programming?
Old Jan 12, 2005 | 07:52 PM
Fleet1's Avatar
Fleet1
Originally Posted by ProtoVette
Come on, that's got to factor in at least 30-40% of the reason I bought and drive a Vette. Not the irresponsible part, but I uselessly spin my tires often. We all know torque is a natural anti-depressive.
Old Jan 12, 2005 | 08:07 PM
Pilot135R's Avatar
Pilot135R
AH is still on when you hit <RESET>. I've confirmed this many times!
Old Jan 13, 2005 | 09:36 AM
Frank V's Avatar
Frank V
But is it still in the "Competitive" mode? There is nothing that tells you that it still is and in my case anyhow, the ability to spin the tires goes away after hitting the "reset" button which leads me to believe that the "Competitive" mode is cancelled but AH in total, is not.
Old Jan 14, 2005 | 01:50 AM
Pilot135R's Avatar
Pilot135R
Yes, the car is still in "Competitive Mode" when you press <RESET>....and yes, I can spin my tires to my heart's content. I'm confident on this point. I used to wonder the same thing as you but it's simply not the case.
Old Jan 14, 2005 | 01:52 AM
KamPow3r's Avatar
KamPow3r
I love that mode!
