Super-fast question, guys!
Old Jan 12, 2005 | 10:23 AM
HadAZ06
Guest
Posts: n/a
Default Super-fast question, guys!
I'm about to order some of the BMW jacking pads that I can lock into my vette and forget about. Just to verify, though, I do need *four* of them, correct? i.e. I've seen picture of the pucks installed right in front of the rear wheels, but not also the front side of the car.
Old Jan 12, 2005 | 10:24 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Yep, 4 is the ticket. That should do you.
Paul
Old Jan 12, 2005 | 10:27 AM
HadAZ06
Guest
Posts: n/a
Paul
Thanks!
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
if you want to leave them in place then 4 is the right number. If you only want to use them when you lift the car then 1 may be all you need, unless you have more than 1 jack....
Old Jan 12, 2005 | 10:32 AM
talon90's Avatar
talon90
NCM Ambassador
Good Point! I just assumed "leave in place"...sorry
Paul
Old Jan 12, 2005 | 01:04 PM
Four would be the number - if you ever have to lift the car all the way off the ground, you will want all of them installed.
Old Jan 12, 2005 | 01:27 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I bought 4 from Bavarian Autosports. I used a small dab of Liquidnails on them to keep them from rattling. You can't see them tucked in there and I believe it's best to always have them on. You never know when something might go wrong and you get stuck at a distant repair shop without pucks.
Old Jan 12, 2005 | 02:40 PM
Merlin02's Avatar
Merlin02
Before you order the jacking pucks, you might want to consider if you may want to have Andy at A&A install a set of rocker rail savers in the future. I had to remove my 4 jacking pucks when the rocker rail savers were installed. The pucks got in the way of the rail savers. Both will not work together.
To Super-fast question, guys!
