Rear view mirror/compass
Old Jan 14, 2005 | 08:22 AM
duds's Avatar
duds
Default Rear view mirror/compass
Are there any replacement rear view mirrors with compass available for my 2000? What is the difficulty of installation? I am new to this board (this is my third post), Everyone has been very responsive with good info. I appreciate the feedback. Thanks Duds
Old Jan 14, 2005 | 09:52 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Hi Duds,
Yes there are replacement mirrors you can get with compass (and usually auto dim as well). Gentex is the company GM gets their mirrors from and they are not too difficult to install. In most cases I think the hardest part of the swap is replacing the existing mirror wiring harness with a new one. You could also check with Gene at Karshop or other used parts sources - maybe you can find a used one that is cheaper than the new ones - they seem to run between $150 and 200....
Old Jan 14, 2005 | 01:33 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Hunt thw down on ebay, get a gm mirror with a compass and the wiring harness. The power hooks up the same way.
Old Jan 14, 2005 | 01:37 PM
screw991le's Avatar
screw991le
http://cgi.ebay.com/ebaymotors/ws/eB...category=33699
http://cgi.ebay.com/ebaymotors/ws/eB...category=50458
The problem is, you need map light to light up the front of the car. If you can live without the light then you can pick up a mirror for dirt
Good luck
Old Jan 14, 2005 | 03:59 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Got mine off of eBay. Gentex is the mfg. Compass with auto dimming. Piece of cake to install.
To Rear view mirror/compass
