Reset Oil Life
Old Jan 14, 2005 | 04:56 PM
utrico's Avatar
utrico
Default Reset Oil Life
I am sure that this has been answered before but how do you reset the oil life monitor after you change the oil?
Old Jan 14, 2005 | 05:00 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
From my 97 Manual:
To reset the OIL LIFE reminder after an oil change:
1. With the ignition on, press the TRIP button so the
OIL LIFE percentage is displayed.
2. Press RESET and hold for two seconds. The word
RESET will appear, then OIL LIFE 99%.
Remember, you must reset the OIL LIFE yourself after
each oil change. It will not reset itself. Also, be careful
not to reset the OIL LIFE accidentally at any time other
than when the oil has just been changed. It can’t be reset
accurately until the next oil change.
Or
You can reset the oil life by pumping the gas pedal 3 times (but not with the engine running)
Paul
Old Jan 14, 2005 | 05:04 PM
ALLEGRO's Avatar
ALLEGRO
Old Jan 14, 2005 | 05:39 PM
Talon90's answer is the way to go.
Old Jan 14, 2005 | 07:34 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Turn the key to on
Press the gas pedel to the FLOOR 3 times Quickly
Turn the key to off
Turn the key to on
Oil is reset
Old Jan 14, 2005 | 09:47 PM
utrico's Avatar
utrico
awesome. thanks guys.
Old Jan 15, 2005 | 01:47 PM
Thunder7's Avatar
Thunder7
Originally Posted by talon90
From my 97 Manual:
This what I did this morning when I changed my oil.
To Reset Oil Life
