Here Kitty Kitty
Old Jan 14, 2005 | 05:50 PM
400hp's Avatar
400hp
Default Here Kitty Kitty
What is the downside (if any) to removing the cats. I have long tube headers and I'm going to install a GHL or B&B cat back. Will there be any power gain if I just eliminate the cats and add an X pipe?
Old Jan 14, 2005 | 05:53 PM
CarsRFun's Avatar
CarsRFun
going to be louder... will need sims or ls1edit,, thats about it.
CAJUNY2KC5's Avatar
CAJUNY2KC5
Might be some slight legal ramifications if caught.......
Old Jan 14, 2005 | 05:56 PM
AFVETTE's Avatar
AFVETTE
You gain about 5 HP plus codes unless you install 02 sims. And I don't want to drive behind a car with gutted cats.
Tom
Old Jan 14, 2005 | 05:57 PM
GMDGary's Avatar
GMDGary
Interesting point, what states have emission laws? All I know is CA and AZ. We don't have any vehicle inspection of any type in Arkansas, so you can run anything anywhere. When I lived in AZ an emission test always cost me several hundred to reinstall all of the required crap, retune the engine to pass, then take it all back off and retune it to run good, but that was better than driving a POS so that some tree hugger could get his rocks off.
Old Jan 14, 2005 | 05:59 PM
400hp's Avatar
400hp
The reason I ask is because I have seen a lot of posts saying that the gains are negligible. However, I used to own a 454SS pickup and when I removed the catalytic converter the thing came alive. I thought maybe the old converter was just blocked, but, when I installed a brand new converter (stock) the thing bogged down again. It was really noticeable.
Old Jan 14, 2005 | 06:03 PM
drochau's Avatar
drochau
Default NM Emmisions
I don't think you can remove/gut the cats in New Mexico and still pass emissions testing. At least not in my county.
Old Jan 14, 2005 | 06:18 PM
torchredfrc's Avatar
torchredfrc
I wasn't aware New Mexico had any emissions testing... what county are you in?
Old Jan 14, 2005 | 06:31 PM
WWK888's Avatar
WWK888
You will also have a gas odor in the cabin when you are stopped and idling. I have read many posts from people saying they regretted eliminating the cats.
Old Jan 14, 2005 | 06:39 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
so I went HHi-flow cats...and no hair *****...
Louder and more agressive with X-pipe and B& B Bullets...
...or take them off...onluy gets louder...
I think there is more power and dyno supports that...
... Ill be listening for you decision...
Old Jan 14, 2005 | 07:02 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Good thread. Interesting observations. I didn't think you would get any smell unless you were burning rich With a catylic converter. With no cats it should be like in the old days of smelling gas out the exhaust. Any ideas?
Old Jan 14, 2005 | 07:06 PM
jers98vet's Avatar
jers98vet
I'mrunning lt's and no cats. The thing is a little stinky at startup but once at running temp. it's fine. Only when my top is down, at a stoplight, in a light, wavering tailwind, can I smell a little exhaust. It's all in the tune imo.
Old Jan 14, 2005 | 07:39 PM
400hp's Avatar
400hp
All in all, it sounds like high flow cats would be the best compromise. No legal problems or potential odors and the performance should be close to a gutted cat or no cats at all........I'm still convinced though that no cats = more power.
Old Jan 14, 2005 | 07:47 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
I'm running off roads pipes and I run a tad rich because of the cam. I picked up 5hp when we removed them. Yeah there was alittle power in crease on the dyno but nothing that I can feel on the street
Old Jan 14, 2005 | 08:01 PM
TampaWRX??'s Avatar
TampaWRX??
In modern NA cars, from what I understand anyway, a good hi-flow cat with properly sized exhaust is damn near as power efficient as no cats at all. In the turbo world, it's a totally different ballgame, but that is what I've read/been told about NA applications.
Old Jan 14, 2005 | 08:06 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
It is against Federal law to remove or replace your cats if your car is less than 10 years old. If they are replaced, they must be replaced by the manufacturer and must have been defective.
All that being said - as soon as I install my LGs, I'm going with Random Tech hi flow cats
I'll go quietly, officer
EG
Old Jan 14, 2005 | 08:18 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Tom
I followed one, who shall remain nameless, in my Vert on a cruise last Fall and talk about smell. Peeyu! There ought to be a law.
To Here Kitty Kitty
Old Jan 14, 2005 | 08:34 PM
sempi's Avatar
sempi
EG
The Federal Law states that you can not totally remove your cats legally at any time, but you cannot replace them unless defective sooner than 50,000 miles or five years. And I could not find anything in the verbage about having to be replaced by the manufacturer. Any muffler shop in CA can replace the cats, if they are proven to be defective.
Sempi
Old Jan 14, 2005 | 08:36 PM
0EG@EnglandGreen
Supporting Tuner
Sorry, I meant the original manufacturer's cats. :o
Old Jan 14, 2005 | 08:38 PM
cerino2000's Avatar
cerino2000
Here in NC, if your car is 1967 or newer (no, that is not a typo) it better have every emmissions piece on it that it came with from the factory or it will not get the required money generating inspection sticker put on it that is required for it to be on the road. Get caught without it and it is a quick $250.
