Codes won't clear
Old Jan 15, 2005 | 01:23 PM
Old Lt's Avatar
Old Lt
Default Codes won't clear
I recently ran the diagnostic test on my 2000 Corvette. There were a few history codes present. On completion of the test I tried to clear the codes by press ing the reset button. The codes did not clear. I ran the test a second time and the codes are still there. They still won't clear by pressing reset. What can I do to clear these codes?
O.L.
Old Jan 15, 2005 | 03:23 PM
Dr. Dan's Avatar
Dr. Dan
O.L.
Had the same problem with Check Engine...Finally took it to a friend who hooked it up to his computer (OBD?) and cleared all of them.
Old Jan 15, 2005 | 03:47 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Try pressing and holding the reset button for a few seconds
Old Jan 15, 2005 | 03:50 PM
Not sure if unhooking the battery for a short time will help. Holding in the reset button should do the trick.
Old Jan 15, 2005 | 04:12 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Just a press won't do it. You need to press and hold for several seconds until it beeps and clears.
Paul
Old Jan 15, 2005 | 04:55 PM
Old Lt's Avatar
Old Lt
Default Thanks to Talon90 & Zilla
Thanks to all who responded to my posting about clearing codes. I took the advice of two forum members. This time I held the reset button for a few seconds. Codes cleared.
Old Lt.
Old Jan 15, 2005 | 04:57 PM
Zilla's Avatar
Zilla
Glad it worked for you
To Codes won't clear
