How to tighten the visor??
Old Jan 15, 2005 | 09:26 PM
saalanghae's Avatar
saalanghae
Default How to tighten the visor??
My visors (both sides) are somewhat loose. The ends wiggles up and down at least 1". I've already took it to the dealer but no help. Is there's any way to fix this problem? It bounces around so much that it begins to bother me. Thank you in advance.
Old Jan 15, 2005 | 10:32 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Are they loose at the pivot point. If so you'll see a ring around the base of them. Use a flat screw driver to tighten them up. Put the screw driver in the slot and turn the visor into the driver in the tightening direction. If your talking about the end that clips into a plastic piece at the hoodliner the looseness maybe due to the other end being loose. Hope that helps. There might be something in tech tips that shows the process of tightening the visors.
