Silver Stars
Old Jan 15, 2005 | 10:15 PM
FastAssVette's Avatar
FastAssVette
Default Silver Stars
I would like to know if anyone has installed Silverstars on there car, and how difficult it is to change the bulbs. Any pics with them would be very helpful. Thanks, Bud
Old Jan 15, 2005 | 10:29 PM
billiam01's Avatar
billiam01
I have and it's not difficult but there is some awkward reaching around and in, and you must not be hamfisted. The bulbs remove and install with a twist and turn and you have to "feel" it out and in. I have a factory service manual and followed it.
Old Jan 15, 2005 | 10:49 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
it takes about 15 minute to change the bulbs
Old Jan 15, 2005 | 10:55 PM
ALLEGRO's Avatar
ALLEGRO
I installed mine in no time flat. Simple directions, three screws and "ShaZam" you have done it.
Quite a difference in color and bightness when you finish !
Old Jan 15, 2005 | 11:12 PM
C6~Missle's Avatar
C6~Missle
Do it.. a worthy upgrade at a very reasonable cost. Not difficult at all to do..
Old Jan 16, 2005 | 12:22 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
How much are these bulbs? I was thinking about doing it. Is there a certain bulb part number of are they all the same? One set for highs and another set for low?
Old Jan 16, 2005 | 12:31 AM
Zilla's Avatar
Zilla
In the US the bulbs are around $30-$35US a pair.
The number are the same, 9005 and 9006
Old Jan 16, 2005 | 12:33 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Low beams are 9006 lamps.
High beams are 9005
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
They are different bulbs for the low and high beams - I can't remember the numbers but they should have a application guide where you get them.
To change them you have to raise the headlights. The safe way to to this is to disconnect the headlight connector (it is just behind the headlight), then use the **** on the back of the headlight motor to raise them up. There is a plastic bezel surrounding the sides and back of the headlight assembly - 3 screws to remove it. Then, as was mentioned above, using your skinniest hand reach in and take out the bulbs - they are a bayonet type of mount, half a twist or so and they come loose.
Old Jan 16, 2005 | 04:02 AM
Stickman81's Avatar
Stickman81
Advance Auto had a mail in rebate a short while ago. If there is one in your area check them out. I'm thinking they are more like $30 each. The standard part number is followed by an "ST" for the brighter white Silverstars. There is also a "CB" for "Cool Blue".
It's an easy mod and you'll be glad you did it when you are done. Open hood, turn on lights to raise the headlight assy, turn lights to "parking" to turn off the headlights. Remove the black plastic housing around the headlight assy. Be careful when pulling the housing off as there is a snap sort of feature in the front, top center of the housing. It takes a little patience. I think you have to wiggle the lower front side of the housing up before the "clip" thingy will disengage. Bulbs take about a 1/4 of a twist to come out. The harness has a little locking tab on it to keep it secured. I try not to touch the bulb glass while I am removing / installing them.
As long as you are in the area, think about changing the fog lamp bulbs, unless you have PIAA's. I think the normal bulb is 893. I changed to the 899. The are about $8.00. It's a bit brighter. I had to adjust the fog lamps up quite a few turns as they were set low.
Welcome to the forum.
Old Jan 16, 2005 | 04:09 AM
USA-VET's Avatar
USA-VET
Old Jan 16, 2005 | 04:40 AM
ownedya's Avatar
ownedya
are they as good as piaa's ?
Old Jan 16, 2005 | 05:39 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Sylvania did have a mil in rebate on their web site, changed hi/low and fog lights to SilverStar
Old Jan 16, 2005 | 07:11 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I have found that it is VERY helpful to remove the painted headlight cover in addition to the black surround. 2 screws at the back tab plus screws on each side of the cover. Cover screws are #15 torx..........
Old Jan 16, 2005 | 07:12 AM
minnasotajim's Avatar
minnasotajim
I changed mine and I do like the SilverStars but a word of caution when putting things back together with your screw driver don't wonder how hard would it be to get the screw driver out of the fender well if it slipped and dropped inside. I had to have my wife come out to the garage and get it out for me my arms would not go that far down
Old Jan 16, 2005 | 07:23 AM
Easy to do following the directions already given - especially if you do not have large hands/arms to try and fit in the headlight assembly. Its a nice mod to do that gives you much better lighting.
Old Jan 16, 2005 | 07:25 AM
mrm1149's Avatar
mrm1149
That's what small children are for!!!!!!!!!!
To Silver Stars
Old Jan 16, 2005 | 08:14 AM
gmosley's Avatar
gmosley
Default silverstars
you can actually get them off ebay for 32 bucks a pair shipped
theyre ok but i wish i would have saved my money to put towards the t 84 euros im getting next week
Old Jan 16, 2005 | 09:04 AM
chasswartz's Avatar
chasswartz
There is an access panel under the car. I don't have a wife.
Old Jan 16, 2005 | 09:08 AM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
just do it
