Cost for new tires
Old Jan 16, 2005 | 01:35 PM
ant21b's Avatar
ant21b
Default Cost for new tires
What is the average cost for a set of goodyear run flat tires including mounting and balancing for my 02 and how many miles should I get out of them.
Old Jan 16, 2005 | 01:42 PM
MalaysianMenace's Avatar
MalaysianMenace
$1000-1200 USD
The trouble might be finding a good run flat installer. Many shops don't install runflats - or if they do, might mess things up (for example, the sensors won't show accurate readings if the stems aren't correctly installed).
I got my last set through a supporting vendor "tirerack.com" over a year and a half ago - prices may have changed since ...
Old Jan 16, 2005 | 01:54 PM
USA-VET's Avatar
USA-VET
around $1000 for a good set!
Old Jan 16, 2005 | 02:21 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
With so many choices available, why GY runflats?
If price is an issue, many members here have bought Kumho, and I'm sure there are a few other choices that don't cost as much as the GY.
Many folks like the Michelin Pilot Sport ZP - but they are a little more costly....
Old Jan 16, 2005 | 02:33 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I think the run flats are more expensive than $1000 my non-runflats cost $1150 after all was said and done. And runflats are more expensive. Try www.tirerack.com or www.discounttires.com they have great sites and give you comparison charts and pricing for what ever tire you want. Personally, I went with non-runflats because when I had runflats I got a flat and couldn't find a place that would repair it. So what's the use in having them? I had to buy a plug kit and repair it myself. So when I got new tires I bought GY D3's and love them. Much quieter than runflats and more traction and they look great. Hope that helps. Buy a plug kit and a compressor and your all set to fix a flat. Don't ever use the fix a flat stuff you put into your tires it makes a mess of the tire pressure sensors.
Old Jan 16, 2005 | 06:08 PM
I'm thinking that the runflats will run about $1200 or so for just the tires. Prices for the mount/balance will vary widely. If you went to a Goodyear store, they will charge you a fortune (at least they do around here). You may want to check around on the mount/balance price - just be sure they have the proper equipment so your wheels do not get damaged. You may want to check with the Tire Rack and see what they are selling the EMTs for.
Old Jan 16, 2005 | 06:18 PM
diyguy's Avatar
diyguy
That was going to be my very next question.
For those that HAVE bought from the Tire Rack, on average.... someone like Discount Tires... WHAT do they charge to mount and balance?
I am thinking of buying 4 tires for my C5, and the Mrs's Grand Cherokee needs tires too. So, mount/balance CHARGES play an important decision.
Anyone chime in with relatively accurate estimates on Cost to mount/balance, and...anywhere better than the next?
Old Jan 16, 2005 | 07:26 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
GY Runflats are still a reasonable option. While Kumho, Michlen, Firestone and I suppose a few other companies also offer run-flats, to my knowledge, only GY can be repaired after you run on them with no air. They can also run a lot longer with no air than most of their competitors.
Old Jan 16, 2005 | 07:29 PM
JACKAL0PE's Avatar
JACKAL0PE
I got mine from the Tire Rack and the local NTB charged me $25 per wheel, mounted and balanced.
Old Jan 16, 2005 | 07:37 PM
vet4fun's Avatar
vet4fun
Prices quoted are accurate. Try Tirerack.com or any others mentioned. As for treadwear/mileage, that varies greatly from car to car. Depends on what type driving you do. My '99 A4 totally wore a set out at 20,000 city-driven miles (and were never driven hard/spun). My '02 6spd. has highway miles, and the fronts have 30,000 and are still going. I've had 2 sets on the rear, and they've only been good for about 15,000 each (4.10's )
Old Jan 16, 2005 | 10:02 PM
gordonb50's Avatar
gordonb50
Bought mine online then went to Discount Tire to have them mounted. Charged me $40 each for mounting & balancing. Good job and warranty. But, could have saved by purchasing them from Discount in the 1st place.
Old Jan 16, 2005 | 10:34 PM
PaPaChoc's Avatar
PaPaChoc
I don’t live close to a big metropolitan area so I guess I’m at the mercy of who-ever. I got mine from a GY dealer and they were like $1600 installed. The guy that installed them was very aware of what he was working on and took great care not to damage anything. In fact I stood right by him the whole time!
diyguy's Avatar
diyguy
That's exactly what I was thinking.. Did anyone actually save anything by the time it was all over and done with, drive away...new tires, mounted and balanced, with disposal fee's, shipping.....what is the bottom line?
Old Jan 17, 2005 | 12:16 AM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
i think its something your really going to have to research for yourself. on average it is usually cheaper to order from tirerack, and have them mounted, and balanced. but it all depends, prices are going to vary from shop to shop. personally, i couldnt see spending $40 per wheel. but then again it helps to know people in the business
start buy calling around to local tires places. have them give you the estimates over the phone including actual tire prices. then you will know which way to go, and how much you are going to save!
Old Jan 17, 2005 | 12:32 AM
unstressed's Avatar
unstressed
I bought a set of rear GSD3's and went to Discount to buy fronts and get everything done.
1st, they said they would warranty the rears I bought elsewhere because they were new.
2nd, matched tire rack price for fronts.
3rd, wanted ~$500 for new fronts, mounting all 4, balance, and warranty for all 4 tires.
4th, didn't have a clue about removing runflats, or how to jack up a vette.
Will go elsewhere, but good pricing. Local forum member recommended a good shop, so I'll check them out.
Old Jan 17, 2005 | 07:56 AM
Tom/99's Avatar
Tom/99
My son in law replaced the two rear tires on his car at 23,000 miles. The new Good Year Run Flats were $850.
Old Jan 17, 2005 | 08:25 AM
dogboy's Avatar
dogboy
try onlinetires.com
To Cost for new tires
