A Little Frustrated ??
I think that the next step is to get the car off of the ramps and just lift the car at the jacking points on each side and slide the jack stands along side the jack. The purpose for this exercise is to add side vent screens and paint the calipers. I also just purchased the GM bra and it will be a much easier install with the front lifted.
So, I guess I have a couple of questions,
1) My new lifing method will work OK ?
2) While I've got the wheels off I probably should paint the hats black as well. Will just brushing on a HT flat black be OK or do these need to be sprayed. It would be some job to mask off.
Sorry for the long post! While laying under the front of the car wondering what to do next I did notice a major amount of crap up at the top of the radiator, leaves, napkins, twigs and other debris. I have heard other folks talk about what they found up there but I thought surely not on my car.
Thanks, Kevin
Chris
that's the way I do it.
1) I didn't see anything about having or using a board to sit on top of the jack to hit the crossmembers. I get the impression that you're going direct from the jack head to the crossmember. Baaaaaad ju-ju. Use a 2x10 about 2 ft. long to span the crossmember.
2) I'm also concerned about using a $50 jack. For god's sake, don't get under that thing with a cheap jack.
If I were you, I'd send a PM to Patches. He's got a really good picture on how to jack it up, where to put the jack stands and where to place the boards.
Jackstands - 4 of them - are your friends. Never, ever go under your car (or remove the wheels) without them.
2 cents deposited
EG
Just because the more you pay for something doesn't mean its better and without problems.
Please use common sense and good judgement.
Jennifer
