Which screens are for? Brake ducts; Side vent or rears.
1. Front Brake ducks: Push in the brake ducting and push it down; Insert the screen provided ( a little tricky - use a long nose plier to hold the screen in one hand and use a screw driver to re-position the ducting - adjust as needed) this is a pressure fit installation.
2. Side Screens: Jack up the car and place it on a jack stand. Remove wheels, remove 5 screws on the wheel well panel (forward of the side vent) and two more screw on the inside of the panel. Align and install the screen provided. Do the same in the other side.
Hope this helps....
Side Screens. I could not figure out how they are suppose to mount to the plastic peice in the fender
I have tried a couple of times, never worked for me, I can't get em to stick. I tried using epoxy one time, super glue one time, and double sided 3M tape the last time... no friggin luck
Form the screen in U shape (if not form) and shape it like the side screen opening. Need to epoxy a 1/8 inch thick of 1/2x1 inch block to the screen (side of U shape) to mount the double sided tape (use an industrial type), use two on each side. http://www.c5frc.com/Installs/FenderScreenInstall.htm
Its not tough.....just ackward to do the install. You have to access the side screen by going through the wheel well. Some remove the wheel, some just turn the wheel. Toughest part for me is getting them to stick in place. Currently, I have one on and the other came loose.
Heres a link to the LAPD website with great instructions.
The screens that fit in the coves do not mount to the plastic piece. The screens should have 3 or 4 clear tabs that have two sided tape on them. Once you have removed the plastic liner that is stock on the car, press the screen up against the cove opening, then peel the tape off of one of the blocks and press it against the side of the fender and the screen. It should stick in place and hold the screen in. Then just do the same for the rest of the blocks. You have to be sure that you clean the area of the fender that the blocks mount to very well - if you do they will stick and hold for quite a while. I installed mine about two years ago and just recently had one of the blocks come loose.
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I had the same problem so i gave them to some member on the forum for nothing i hope he had better luck with putting them on then i did.They would fall off evreytime i hit a small bump.
Zilla You gave me the Hot Glue tip and I tried it, but for the life of me, I couldn't get the one to "stick" good. Maybe I didn't clean it well enought.....but Gee
i cleaned the inside of the cove with acetone then appied them per the instructions with the blocks and then i took a caulking gun with silicone adhesive and a foot of clear 3/8 tube on the nozzle, and applied it around the edges where it isnt seen, i really dont think i'll have any problems, their good and secure.
