Safe Warm Up?
Old Jan 18, 2005 | 11:34 AM
bangbgC6's Avatar
bangbgC6
Originally Posted by George8211
I try to let mine idle for a few minutes before I drive it.... I like to see the water temp gauge moving before I do any hard driving or high revs. I like to know the valve springs are warmed and ready.
As far as the opinions from members from Texas, South Carolina, Alabama, Arizona go....
As if you know what we're talking about
Michigan... Current temp 2 degrees F BRRRRRRRRRR
Very true we have a very limited perspective and experience.
I can tell you for a fact that at 2 degrees I won't be going anywhere period. In fact I hope the only time I'm that cold is after I'm in the box. When it was 25 degrees here and I started the Vette the oil temp was 59 degrees and I literally felt pain at the thought.
I'm amazed at the technology that allows oils to flow and work at that temperatures effectively!
Old Jan 18, 2005 | 11:40 AM
gsxrjack's Avatar
gsxrjack
Originally Posted by EnglandGreen
I'm "Old School".
I let it warm up to operating temps (over 160) and then slowly move off. Wait till A4 and tires warm up before getting on it hard.
Cheaper than breaking something (like a dropped valve or ring land)
My 2 cents
EG
Im just OLD, i warm up the car in the winter untill its warm enough IN the car...
Old Jan 18, 2005 | 11:42 AM
George8211's Avatar
George8211
Take a close look at the option list when looking at new vehicles. You may see an option called an oil warmer. This option is some times selected by people in the Northern part of the U.S.... and in Canada.
It's a heating element that goes into your engine and has a plug-in cord behind the front grill. You plug in when you get home and it heats the oil to keep it from getting too cold
So if you ever see an extention cord looking thing sticking out the front of someones front grill.... you'll know what it's for.
Most of my family lives in Northern MN near International Falls.... last night -22F.
Old Jan 18, 2005 | 11:43 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Slightly off subject. but someone posted last week asking if the climate control and DIC gauge could display negative numbers. This morning it was like negative 5 (celsius) and both gauges show negative numbers...
and to add to this disucssion, I let it idle for a few minutes but not long really and took it easy, the engine wasn't even up to 150 degrees when i got to where i was doing--talk about a cold ride!!
Old Jan 18, 2005 | 11:59 AM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Hey
I like to wait for over 100 engine oil but take it easy till trans temp is at 100. I have a 25mph neighborhood that I drive through to get to faster roads. Low RPM's and easy starts and stops. "0" degrees today-took long time to warm up. Tires only came up 2lbs after driving about 25mi.
I keep trans temp on and watch it most of the time. Works for me.
Old Jan 18, 2005 | 12:21 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I seem to have NO traction in this super cold weather. Last night I bearly tapped the gas while making a turn at an intersection (with traction control off hehe) and about slid around 180 degrees, oops
Old Jan 18, 2005 | 12:26 PM
YBNORML's Avatar
YBNORML
BE CAREFUL!!!!!!!!
With the cold air flow and the rock hard runflats it's too easy to get squirrley
Old Jan 18, 2005 | 12:33 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Leaving traction control on now
Old Jan 18, 2005 | 12:48 PM
Originally Posted by RocketDawg
I'd always been taught that you start it up and get it moving as soon as possible ... don't let it sit there idling. Just drive it slowly until it's up to operating temperature.
Not sure that's the proper thing to do, but it's what I've always done.
This is the way I drive mine also.
Old Jan 18, 2005 | 12:53 PM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
I think I may have started a thread like this about a month ago and what I took away from the quality replies was that Coolant Temp was a preferred indicator over Oil Temp. It was 14' this morning and I took it easy until the Coolant Temp was around 150... Having it in the garage is key- probably not any colder than 45-50 degrees...
Old Jan 18, 2005 | 12:56 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Maybe it is okay to start it and go so long as you take it easy at first, but there is no way anyone is going to convince me that letting it warm up at idle for a while is bad.
I have read many times in different places where the most wear and tear in an engine occurs upon start up..so how can letting the car idle and warm up not be good. Doesn't metal expand and contract with hot and cold?
Old Jan 18, 2005 | 01:02 PM
BigJoe's Avatar
BigJoe
Yeah, yeah.. But I lived in Chicago for 40 years before moving to the "sunny South" so I know about cold... I did the same thing there. Start and go, slowly until everything, not just the engine, is warmed up.
When it's -26 warming up the tranny, tires, even the suspension is just as important and you don't get that idling in the garage... So you have a nice warm engine and you hammer it only to pick up your tranny off the road.
Old Jan 18, 2005 | 01:03 PM
  #33
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'm in NC...high here today is 30, low was like 13 and it's fairly windy on top of that. Pretty freagin cold for the 'south'
Old Jan 18, 2005 | 02:53 PM
  #34
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Boy do I feel your guys pain. I got in my car this morning and it was 67 degrees outside. I "Almost" got cold. Looking out of my office window I think I see a cloud...
For what its worth I'm glad this thread came up cause I always waited until my coolant temp went above 100 for the first time this morning I waited till the oil went above 100.
But that was only about 2 minutes cause it was 97 when I started the car.
Old Jan 18, 2005 | 03:03 PM
  #35
schpenxel's Avatar
schpenxel
St. Jude Donor '15
(insert middle finger smilie here )
It was around 70 last Friday when I woke up (8am) by 11am it was down to the 40's and hasn't went back up since. Damn cold fronts.
Old Jan 18, 2005 | 06:24 PM
  #36
George8211's Avatar
George8211
Try this one.... About two years ago it was like -45 in International Fall MN and high winds. My dad his his 4x4 parked outside over night and snow and ice hardened around his tires. He went to drive off and blew both of his rear tires because of the cold.
Old Jan 18, 2005 | 06:30 PM
  #37
MY1STPEWTER's Avatar
MY1STPEWTER
High here today was about 30. Went for a ride around 2 pm and when I started it up I got LOW on oil temp. First time I got this. I let it idle in garage, (with door up) for about 10 minutes b/4 leaving. Still had LOW on oil temp, turned off and reading did not go away. Coolant was around 170 so I know oil was ok. Made a short stop while I was out and when I restarted I finally got reading. Did a search on this when I got home and apparently it's normal. Don't know how necessary warming up really is, but on this ride it will be warmed up several minutes b/4 I take off when it's cold.
To Safe Warm Up?
Old Jan 18, 2005 | 06:43 PM
  #38
VetteDrmr's Avatar
VetteDrmr
The problem with idling isn't the slow warmup, it's the water vapor that's a part of combustion blow-by. When the engine warms up slowly you can get a lot of water absorbed by the oil. That water has to be evaporated out (oil temp does NOT need to be 212, but that's a different story) or acids will form, and that's what's bad.
What I do is 2-part: Normally I wait until the idle and oil pressure have stabilized, then move out slowly. If it's REALLY cold then I wait until I can stand sitting in the car! Yeah, call me a wimp! When it comes to cold, that's me!
Have a good one,
Mike
Old Jan 18, 2005 | 10:34 PM
  #39
Jim2003's Avatar
Jim2003
I realize that I am an old guy (60) and that I have driven a few cars in my life. I have never WOT a cold car of any type. I also have never let a car sit and idle to warm it up. I normally and easily until I get to the interstate and then go the speed limit plus. I sold my 1997 Z-28 Camaro when I bought my 2003 Vette. I had 89,000 on the Z-28 and never a problem and it used regular oil not the synthic oil of the Vette. I believe that too many people are afraid to use and drive the cars normally. Our Vettes are the ultimate driving machine not a weak under developed and under engineered machine. My is my only car and my daily driver. It is a real joy to be in every day.
Old Jan 18, 2005 | 10:41 PM
  #40
chocoholic's Avatar
chocoholic
I've a question for those that are agonising about when it's safe to drive their cars.
Did, or do, you have this consideration on your previous or other vehicles? If not, why not and how many of those cars died a gruesome death? Any at all?
