Courtesy "Ding" sounds blown?
Old Jan 17, 2005 | 06:31 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Courtesy "Ding" sounds blown?
Recently I've noticed that the 3-5 dings that go off when you put the key in the ignition sounds like the speaker (as if there were one) is blown. I'm getting disheartened between this new issue, the rocking seats, cooing A/C (yes, cooing like a pigeon), rattling windows and whistling intake.
This "blown dinger" makes the car sound really cheap, more like a Chevette than a Corvette. Anyone ever heard of this?
Old Jan 17, 2005 | 06:36 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
Nah, my dinger still works fine. And the AC hasn't started cooing yet ... but I do get a little wind noise. But the intake doesn't whistle.
Old Jan 17, 2005 | 06:40 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Yes there`s a speaker...its part of the Instrument Cluster and it is replaceable, once the cluster is removed and on the bench.
Old Jan 17, 2005 | 06:46 PM
NSTG8R's Avatar
NSTG8R
Rocking Seat - http://js-x.com/robbs/ken/vette1/
A/C Cooing - no idea .. need further desc.
rattling window - check bolt behind reflector on door, make sure it's tightened down .. also if there is an air noise from your top, it need adjustments.
whistling intake - possible air leak? would depend on intake setup.
Old Jan 18, 2005 | 10:39 AM
5 Liter Eater
St. Jude Donor '11
Thanks for the info. I should have mentioned I've tried some of these already. The rocking seat fix did not appear to work on my passenger seat. I have done the tip in adjustment but they still rattle and there are air leaks. The whistling intake I am referring to can be fixed here: http://www.corvetteforum.net/c5/c5tech/ but I have yet to fix that either.
There are noted fixes for all my gripes (even the dinger apparently), I just need to do them. It's just getting to be a bit much (and I like working on cars). To boot my nitrous is on the blink.
12stepvette, thanks for the info on the speaker. I guess now I have another reason to pull my cluster besided painting the bezels.
Old Jan 18, 2005 | 01:23 PM
Thanks for the info. Never thought about it having a separate speaker for this, but it does make sense.
Old Jan 18, 2005 | 01:38 PM
5 Liter Eater
St. Jude Donor '11
I just don't get how it 'blows out'. Not like I cranked up the volume on my courtesy ding.
Old Jan 18, 2005 | 01:42 PM
12stepvette
Its just a cheap little paper speaker....Now that I think about it...it looks exactly like the ones you find in a PC tower....same connector too I believe!!!
Old Jan 18, 2005 | 01:51 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
cialis will get your dinger back up..
Old Jan 18, 2005 | 01:54 PM
saalanghae's Avatar
saalanghae
I have the same cooing A/C noise from my 04 Vert. I took it in (3 times) for service but they said "Cannot duplicate the problem".
They are making it sounds like that I'm the only one hearing the noise and it is perfectly normal what they hear from my A/C.
How can I convince them about the noise? To me it sounds pretty loud but for them, they can't hear it!!! Aaaaaarg.........
Old Jan 18, 2005 | 03:11 PM
jrose7004's Avatar
jrose7004
Old Jan 18, 2005 | 03:19 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Score one for Grumpy, even though I thought that would only work for the DIC!!!!
Old Jan 19, 2005 | 12:14 PM
5 Liter Eater
St. Jude Donor '11
I'm not sure but I can say that this sound was not there prior to the car being down for ~ one month due to a snapped output shaft.
I may try the drilling the blower motor housing and oiling it but I can't understand why it would only occur when the A/C is on.
Old Jan 20, 2005 | 11:33 AM
5 Liter Eater
St. Jude Donor '11
I was listening to it again today and the cooing does not change pitch with blower motor speed. I am thinking now that the problem lies with the expansion valve which lets freon into the evaporator to cool the air moving across it. I think it may not be able to close completely and freon is leaking by which creates the cooing sound. When the A/C is turned off the pressure drops enough to allow the expansion valve to close.
This is my theory but I'm not bugged by it enough to crack open my A/C system to test it out. I don't know if you can convince the dealer that this is what is happening to have them try to replace the expansion valve to see if it stops the cooing.
Old Jan 20, 2005 | 01:53 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Hey, whose moderating this thread? Lock up this post!!
Old Jan 20, 2005 | 05:00 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Old Apr 27, 2005 | 04:26 PM
5 Liter Eater
St. Jude Donor '11
Jut an FYI for anyone who may encounter the 'cooing" noise from the A/C in the future: My A/C also started blowing not so cold soon after the cooing started. I didn't do anything about it because it was winter at the time but now that it's warming up I hooked up my A/C gauges and I was about a can low on R134. After adding about a can (whatever it took to get the pressures right) it blows cold AND no longer makes the cooing sound.
HTH
PS: I have also since done the rocking seat fix and fixed my window rattling!
To Courtesy "Ding" sounds blown?
Old Apr 27, 2005 | 07:05 PM
98NassauBluC5's Avatar
98NassauBluC5
From: I'm a Texan, but I traded the horse for the Vette.
You know, mine has done the same thing. I'm curious as to how much and where to get it comes into place?
Old Apr 28, 2005 | 09:36 AM
5 Liter Eater
St. Jude Donor '11
R134? You can get it at any parts store, at least here in Texas. Then you need the gauges (got mine @ Harbor Freight) that tell you what the high and low side pressures are at. Then you look up in the service manual what the pressures should be at a given ambient temp and humidity and add freon until you get there.
Old Apr 28, 2005 | 09:49 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
The Grumpmeister strikes again!
