Outside Temp Sensor
Old Jan 20, 2005 | 06:38 PM
Z06 Mike's Avatar
Z06 Mike
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Outside Temp Sensor
My outside temp reads a constant 69 degrees. I think the wires by the sensor near the intercooler got disconnected somehow. I cannot find the friggin' wires though. Anybody know exactly where I should look? (The only wires I can find go to the hood light).
Old Jan 20, 2005 | 07:18 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Yes, you have a bad connection or the sensor has came unplugged. The sensor is on the bottom, passenger side of your radiator shroud. Could just need plugged back in.
Old Jan 20, 2005 | 07:41 PM
jim49tx's Avatar
jim49tx
and the sensor is very cheap. I think I paid 8 bucks (or there abouts) at the dealership. I had my car in for the Column Lock recall and he put it in for free.
Jim in Amarillo, TX (hopefully Pompano Beach will be home soon)
Old Jan 20, 2005 | 07:46 PM
Z06 Mike's Avatar
Z06 Mike
So I should be able to see it in plain view if I am looking straight up at the radiator shroud from underneath the car. I wonder if it's gone then. What does it look like? (Anyone have a pic??)
Old Jan 20, 2005 | 08:04 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
This is interesting! I've had the shroud off and don't remember seeing any sensor.
Old Jan 20, 2005 | 08:35 PM
RCK1999's Avatar
RCK1999
Lay in front of the car and look up into the shroud. At the very bottom passenger side you should see a small cut-out with a black plastic tip sticking through about 1/2".
Old Jan 20, 2005 | 11:37 PM
Stock Man's Avatar
Stock Man
I'll check it out. Thanks.
Old Jan 20, 2005 | 11:46 PM
PlayasJoint's Avatar
PlayasJoint
could someone please take a pic of it...i have the same problem! i thought my car was just retarded! so could some one please take photo and circle it? id be much appreciated!
Old Jan 21, 2005 | 07:07 AM
Patches's Avatar
Patches
Old Jan 21, 2005 | 09:49 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Damn, that's slick.
Old Jan 21, 2005 | 01:20 PM
That's it. You may be able to see the wires by opening the hood and looking down the side of the radiator shroud.
Old Jan 21, 2005 | 01:46 PM
ALLEGRO's Avatar
ALLEGRO
Outstanding Patches !
Old Jan 21, 2005 | 06:47 PM
PlayasJoint
thank you sooo much for that picture! i am out of town in dallas for the weekend, and i will look at it when i get back! thanks!
Old Jan 21, 2005 | 09:49 PM
Z06 Mike's Avatar
Z06 Mike
I think my sensor is gone...
Probably when I replaced and lowered the radiator when I upgraded the blower.
Old Jan 22, 2005 | 10:11 AM
sts57c5's Avatar
sts57c5
if you have to buy one it is cheap i had to replace mine this summer.
To Outside Temp Sensor
