Oil Life
Old Jan 21, 2005 | 07:49 AM
duds's Avatar
duds
Default Oil Life
How do you activate the oil life percent. I have not been able to find it. Thanks, Duds
Old Jan 21, 2005 | 08:16 AM
Silver98's Avatar
Silver98
Duds,
You don't have to 'activate' it, it's an algorythm run by the PCM. To 'access' it, use the DIC and go to "trip" by pressing this button on the right side of the IP (Instrument Panel). Whan you press it the first time, the odometer will be displayed, continue to press the "Trip" buttone to scroll the display. You will see Trip A, Trip B, Elap(sed) Time, Avg. Speed then OIL LIFE REMAIN. when you change your oil, remember to scroll to the display of Oil Life and while it is 'up', press the RESET button at the botttom of the DIC control buttons. This will reset the Oil Life Remaining to 99%. Do NOT press the Reset while the Oil Life Remaining is displayed any other time, as this would invalidate the oil life monitor.
Hope that helps (HTH),
Joe
Old Jan 21, 2005 | 08:31 AM
duds's Avatar
duds
Default Oil life
Thanks very much, I appreciate the input. Duds
Old Jan 21, 2005 | 08:33 AM
duds's Avatar
duds
Default Boyertown, ?
Joe I just caught the Boyertown, Pa on you signature,. I lived in Boyertown from 1972 through 1995 till I moved to Orlando.
Old Jan 21, 2005 | 01:24 PM
Pretty easy to do once you have done it. It should be explained in your owners manual also.
Old Jan 22, 2005 | 07:57 PM
chimknee's Avatar
chimknee
St. Jude Donor '06
Default When...
Did the oil life % monitor become available beginning with the C5. I have a C4 and can find no mention of it in the manual. TIA
chiminey
Old Jan 22, 2005 | 08:07 PM
Shylor's Avatar
Shylor
The C4 does have an oil life monitor, it just doesn't show you the % of life left, as the C5 system does.
To Oil Life
