Headlight Gone Nuts Help!
Old Jan 21, 2005 | 03:37 PM
Torched's Avatar
Torched
Default Headlight Gone Nuts Help!
I had to take off the rubber boot to make a adjustment to the driver side headlight using the manual ****.. after i lowered the headlight manually i tried the lights the door opens fine except the round **** to manually raise the door makes a loud noise and keeps spinning(it's suppose to stop spinning) when closed is there a adjustment for this or is it dealer time?Has the motor gone bad? Help Greg
Old Jan 21, 2005 | 03:43 PM
Bman's Avatar
Bman
St. Jude Donor '05
Sounds like a striped gear.
Check this out!
http://forums.corvetteforum.com/showthread.php?t=991640
Old Jan 21, 2005 | 03:46 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Sounds to me like a bad nylon gear (broken teeth).
When the gear in mine went it would make a noise after putting it in the down position but would shut off after a while.
I bought a brass gear and replaced it myself.
Old Jan 21, 2005 | 03:47 PM
Bman's Avatar
Bman
St. Jude Donor '05
Well, on second thought i forgot to ask what year. If its still under warranty GM will take car of it but they will replace it with the same nylon gear and it will probably do it in the future.
The brass gear is the way to go.
Old Jan 21, 2005 | 04:09 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Try this link for a fix:
http://forums.corvetteforum.com/showthread.php?t=902024
Old Jan 21, 2005 | 04:45 PM
Torched's Avatar
Torched
Thanks guys for all your replies very helpfull. My car is a 02 Z06. The factory warrenty has expired. I have a extended GM major guard warrenty. I have a Euro code class lights with HID do you think that will void the warrenty? can this gear be replaced without realigning the headlights? Should i play stupid with the add ons. Greg
Old Jan 21, 2005 | 07:02 PM
Torched's Avatar
Torched
Does anybody know if the motor can be replace without the headlight needing a realignment? Greg
Old Jan 22, 2005 | 10:09 PM
Torched's Avatar
Torched
ttt
Old Jan 23, 2005 | 04:07 AM
sebringsilver97coupe's Avatar
first of all, the manual **** isnt for adjusment. its to open/close manually. the adjustments are all in screws and bolts, not the ****.
secondly, id repalce with brass gears for 50 or so bucks as a DIY thing, if u get them replaced with gm ones they will just break again.
To Headlight Gone Nuts Help!
