replacing gas pedal
Old Jan 21, 2005 | 04:22 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default replacing gas pedal
I was intrested in replacing my standard gas pedal in my 03 with one of the metal ones they advertise in the car books and wonder how hard of a job it is to do .I have looked at the pedal in the car and i cannot figure out where this thing comes apart and i am afraid if i goof it up i wont have a gas pedal at all.Can someone give me any suggestions.Thanks Charlene
Old Jan 21, 2005 | 04:32 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Old Jan 21, 2005 | 04:47 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I replaced mine. Dead pedal is very easy to install. Gas pedal, however, is a royal PITA but the results are well worth the time and patience
Old Jan 21, 2005 | 05:11 PM
SmokeyTirez's Avatar
SmokeyTirez
And now to answer your question..
The gas pedal is held on to the pedal bar with a single pin. The pin slides through the pedal and the bar and is held on one end with a clip. I believe the clip is on the right side if you are looking at the pedal face.
There is also a little spring in there so the pedal doesn't flop around. The pin goes through the spring and the spring sits against the pedal.
It's easy to do. Just takes a few mins to figure out what's happening behind the pedal.
My 0.02: Borrow your wife's/girlfriend's/mom's makeup mirror and put it on the floor under the pedal. That way you can see what you're doing.
Cheers,
Old Jan 21, 2005 | 05:17 PM
Didn't know how the pedal came off. Thanks for the info.
Old Jan 21, 2005 | 05:21 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Cheers,
Correct, and use the mirror if you do not want to end up really frustrated!
Old Jan 21, 2005 | 05:31 PM
dragon84's Avatar
dragon84
I didn't replace mine, but I did jaz them up a bit.
Old Jan 21, 2005 | 05:55 PM
Blue Lion's Avatar
Blue Lion
Charlene, did you wear out the gas pedal already?
Old Jan 21, 2005 | 05:56 PM
charlene's Avatar
charlene
Cheers,
Well since i am a gal and dont have a wife.and mom's been gone these 20 years and a girlfriend of mine lives to far to borrow her mirror i guess i will have to use my own if i do the job at all.thank you and the mirror is a good idea because you can't see behind that darn pedal.
Old Jan 21, 2005 | 06:08 PM
charlene's Avatar
charlene
Cheers,
I will have to take alook tomorrow with a mirror since it is dark out here now and tomorrow we are suppose to have between 5 and 10 inches of snow so i will have plenty of time to check it out guess i will need a flash light to.thanks
Old Jan 21, 2005 | 06:11 PM
charlene's Avatar
charlene
No i have not worn out the gas pedal you are lucky you live in florida and you can drive everyday my car has been stored since the end of oct and we are getting more snow tomorrow,oh where is summer i need summer.
Old Jan 21, 2005 | 06:37 PM
LoneStarFRC's Avatar
LoneStarFRC
I did this on mine a couple of years ago, and gave up on trying to struggle with this job while down on the floorboard. I recommend you do as I did and remove the gas pedal assembly from the car and put it on the bench to make your change. Then you will be able to see how the little spring is installed on the little cross pin, etc, and it's a piece of cake. As I recall there were three bolts to remove and of course the plug-in wire harness. No need to disconnect the battery or reprogram anything. Just don't turn on the key until your finished to be on the safe side. HTH
Robert
Old Jan 21, 2005 | 06:50 PM
SmokeyTirez
Hah! Didn't pay attention to who was posting. Just answered the post. My bad.
Old Jan 21, 2005 | 06:51 PM
SmokeyTirez
Robert
That is all a lot more work than is necessary. I'd recommend against following these steps just to replace the pedal.
No offense LoneStar..
Old Jan 21, 2005 | 07:00 PM
Tiger Shark's Avatar
Tiger Shark
Here's an online review that mentions some installation tips...
Full review: http://www.tigersharkcorvette.com/ma...t_20040616.php
"Accelerator Pedal: First the spring must be lifted over the pedal arm to relieve tension on the stock pedal. The pin must next be removed while holding the spring in place. Then, while continuing to hold the spring in place, the stock pedal can be removed. The new pedal is then placed into position while the spring is kept in its original position. The pin is then placed through the holes and the spring. The spring is then lifted back over the pedal arm putting tension back on the pedal. That's it!"
Hope this helps!
Old Jan 21, 2005 | 07:02 PM
mjmc1273's Avatar
mjmc1273
Cheers,
Exactly ...........
Old Jan 21, 2005 | 07:03 PM
LoneStarFRC
Non taken. It's just that it is far easier to remove the gas pedal assembly than you may think. Besides that you've eliminated the need for the flashlight,mirror, cramped working conditions, can't fit down there, thing. Remember, that little spring has to be re-installed a certain way in order for the pedal not to rattle, and it is way easier to do all this when on the bench.
To replacing gas pedal
Old Jan 21, 2005 | 07:04 PM
Tiger Shark
Here's an online review that includes some installation tips...
Hope this helps!
Old Jan 21, 2005 | 08:42 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
If brown would ever bring mine I could follow along.
Old Jan 21, 2005 | 08:48 PM
JeepTJ's Avatar
JeepTJ
Hope this helps!
I bent the spring just a bit, so the new bolt would go thru. Very easy to do. And no need to remove anything.
