What's the best battery
Old Jan 23, 2005 | 12:54 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
I'll go ask my girlfriend
Old Jan 23, 2005 | 02:03 AM
zguy's Avatar
zguy
Originally Posted by Sportsdude
I went with Optima Red and it works great!
Had mine for 18 months now. No problems whatsoever. Looks good under the hood as well...
Old Jan 23, 2005 | 02:05 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Optima Yellow. I have a killer stereo.
EG
Old Jan 23, 2005 | 02:16 AM
JETZ's Avatar
JETZ
EG
Which model # yellow top did you use?
Old Jan 23, 2005 | 02:31 AM
3RD-INF's Avatar
3RD-INF
Originally Posted by CAJUNY2KC5
Cool. Can you tell me when I'll be able to pay cash for a new C6 Z06?
If your like me, it's after I got both children married and moved out of the house.
GrayC5's Avatar
GrayC5
IMO, Optima batteries are an excellent choice. However, I often see them referred to here on the Forum as a gel cell battery. Actually according to the Optima website, the Red Top and Yellow Top are Absorbent Glass Mat (AGM) batteries and there is a diffference:
"All you ever wanted to know about AGM and Gel Cell batteries"
Good luck with the new battery.
Old Jan 23, 2005 | 07:25 AM
Patman's Avatar
Patman
Originally Posted by StephenT
Since when is 7:30 before 7:29 ?
Look closer at the beginning of the thread. This thread was started by Sandy99Pewter, but yet that post ends up being at 7:30, and the first reply to it is the one at 7:29.
Old Jan 23, 2005 | 08:20 AM
I like my Optima Red Top.
Old Jan 23, 2005 | 08:33 AM
PYRO1's Avatar
PYRO1
RED TOP
Old Jan 23, 2005 | 09:20 AM
whiteyvert01
This forum is fantastic. Can't think yall enough..........
Old Jan 23, 2005 | 09:47 AM
Twospeeds's Avatar
Twospeeds
Default Yellow or red.
What is the difference between the Optima red and yellow top, and is one better than the other. Thanks, John.
Old Jan 23, 2005 | 09:55 AM
blonzz's Avatar
blonzz
Those of you that have replaced your battery in your C6 with a redtop what model # did you use?
They don't have a selection for the 05 on their site.
And was it a direct replacement?
Thanks,
John
Old Jan 23, 2005 | 09:57 AM
  #33
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
The yellow top is what's known as a "deep cycle" battery. They're generally used in things like boats and RV's where they're intended to be discharged and then recharged. Personally, I don't think they're a good idea for single battery cars although some here believe they're good for high-capacity users.
Old Jan 23, 2005 | 09:59 AM
  #34
JACKAL0PE's Avatar
JACKAL0PE
Thanks,
John
I think it's a size 75 and if I've got the size remembered correctly, yes, it's a direct replacement (although you have to use a different battery hold-down which is supplied with the battery).
Old Jan 23, 2005 | 10:25 AM
  #35
0EG@EnglandGreen
Supporting Tuner
Quote from the Optima website:
"OPTIMA Yellow Top batteries, featuring SPIRALCELL Technology, are designed for all of your deep cycle needs. It's perfect for people who are serious about sound. OPTIMA's power is cleaner with higher voltage output than conventional batteries. You can play your system louder and longer. And they have a greater cycle life so they can be drained and recharged more often."
I have a 1 Farad Cap with my sub amp and I love the Yellow Top - no more dimming lights when the 12inch Rockford Fosgate Stage2 hits at 25Hzs.
All that, plus like all Optima batteries, it can sit unused for a year and not discharge.
EG
Old Jan 23, 2005 | 10:50 AM
  #36
Yoggi's Avatar
Yoggi
Old Jan 23, 2005 | 10:53 AM
  #37
Blue Lion's Avatar
Blue Lion
Every time this question gets asked, you get the same answer: Optima Red Top. There is another thread on C5 General right now that lists the costs people have paid.
To What's the best battery
Old Jan 23, 2005 | 11:52 AM
  #38
ProtoVette's Avatar
ProtoVette
I got the Nascar Excide AMG type sold at Sam's Club for $95. That's an extra $20 or so for other mods or whatever, compared to the RedTop. They really are essentially the same battery. You just pay for the "RedTop Optima" name. Dont let anyone tell you differently and say "RedTop is a better battery" just because they bought one. Ask them to prove it.
Only had it a few weeks, but zero problems. Which is the way it should be. I've read in several post where the RedTops went dead after a few days of not starting the car or even went bad all together. In my opinion, for that kind of money, you should not read one post about the battery going bad.
Also, you will have to re-sycronize your keyfob to you car after you replace your battery.
Good Luck on your choice.
Chris
Old Jan 26, 2005 | 08:25 PM
  #39
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Originally Posted by USA-VET
Nice batteries.
Old Jan 26, 2005 | 08:31 PM
  #40
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Originally Posted by Patman
How did the first reply to this thread end up having a time before the original post?
They adjusted the forum clock. When you move the clock back, later posts (after the time change) will take on the new forum time, which if earlier, will put the posts in above the posts made before the time rollback.
If the forum clock happened to run slow, and they bumped it forward, there would be no noticible effects...it's only when time needs to be set back that these weird post arrangements occur.
And, oh yeah...Optima red top here.
