99 Vert Axle Options
Old Jan 23, 2005 | 02:51 PM
caffeine's Avatar
caffeine
Default 99 Vert Axle Options
Just received my build sheet from NCM. My axle is 3.42. What axle options were offered in 99 and what was the difference.
Old Jan 23, 2005 | 02:58 PM
MacA1979's Avatar
MacA1979
Always Shiftin'
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (stock)
I am assuming that your '99 is a 6 speed. The 3.42 rear gear ratio was standard for the 6 speed. I don't think you had any other option with the manual transmission. The automatic had a std 2.73 and I think could be upgraded to a 3.15(?).
Old Jan 23, 2005 | 03:07 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
All 6spd cars were 3.42, no optional ratios.
Automatic cars came standard with 2.73. 3.15 was optional.
Simply put, the higher the numerical ratio, the faster the car will accelerate, and it will be running at a higher rpm in any given gear at the same speed.
Aftermarket ratios offered are 3.73, 3.90, and 4.10 for those wishing even more. The 3.42 ratio is also a popular upgrade for A4 owners.
To 99 Vert Axle Options
