License plate lightbulb replacement
Old Jan 23, 2005 | 08:13 PM
YellowFlash's Avatar
YellowFlash
CI 7 & 9 Veteran
Default License plate lightbulb replacement
Does anyone know how to replace the rear license plate lightbulbs on a '01 C5 coupe? One of mine blew out and before I start unscrewing things I thought I'd ask if anyone else knows how to replace them.
Old Jan 23, 2005 | 11:32 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Remove the trim ring around the plate. There are four little tabs that you push in on the sides of the frame to get it off. Then remove the plate and then you'll see the four screws to remove the whole assy. Not to hard eight screws altogether.
Old Jan 23, 2005 | 11:36 PM
YellowFlash
CI 7 & 9 Veteran
The bulbs are above the assembly and don't appear to be connected; do I need to remove the license plate assembly to replace the bulbs?
Old Jan 23, 2005 | 11:41 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
You can do it...just say that..."I can do it"
replacement bulbs should be easy enough to come by...
..hmmmm I think EnglandGreen bought up all supplies of neon...
To License plate lightbulb replacement
