I have a problem with the passanger side hedlight. It does not seem that it closes all the way down, as to align with the hood/body of the car. It is just a slight misalignment. The manual adjuster is screwed all the way down, if that is how you would say that? But the light still stands up a bit?
What am I missing? Is there something it might be hitting? How is this adjusted?
I have the same issue, but with the driver's side. When the lights go down, the driver's side comes back up just a bit. I can crank the manual adjuster and get it flush. It seems like the "stop", if there is such a thing isn't quite adjusted right.
I had both headlights replaced on my 02 (don't ask why). If you remove the top cover to the headlight (the painted part - should be a couple of screws in the rear and on the side) there is an adjustment plate underneath that you can manipulate. However, this is a pain in the butt.
