C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Need help with code 420!!!!!
Old Feb 4, 2005 | 11:32 AM
rudolph schenker's Avatar
rudolph schenker
Default Need help with code 420!!!!!
I have installed GHL long tube headers with GHL Bullet exhaust. I also have a Vararam. The problem is the check engine light comes on intermittently, usually after 1-1.5 hours of operation. I've checked the display and get 0420 H C. Can Catalytic converters be defective? (I have R T metal matrix high flow cats). Would a leak cause this? Any other ideas or input would be appreciated.
Old Feb 8, 2005 | 11:20 PM
breezn24's Avatar
breezn24
I had the same engine code start popping up a few weeks after installing Dynatech headers, cats, and x-pipe. Turned out to be an exhaust leak in one of the cats; the cat had a defective weld. I suggest you try the following, in this order: (1) check for an exhaust leak near the cats, (2) get a tune if you haven't had one, and/or (3) replace the rear 02 sensors with Bosch sensors. Good luck!
