Halltech Stinger LTFT Issues
This is what's happening: LTFT's are around +13 at idle with the hood open. Close the hood, they go to near +20. Went for a ride today, got home hooked up EFI Live and start logging with hood closed, LTFT's at +20/21, open the hood and it goes down to +13/14, close the hood again and they shoot back up to +21. What the he!! is going on. Spend money on an intake that I can't even use. I hear that a 01 Maf will help, spend money on that and I still can't use the damn intake. Help!
Check your bridge fitment. It is possible that closing your hood puts pressure on a joint and is letting air seep in behind the MAF. If the weather cooperates this week, I am gong to get mine out and do some data logging.
BTW, I had a few baseline dyno runs Friday and my AFRs were really high. Average was around 14.5 and went as high as 16 in a couple of instances. I'm not sure if the shop's wideband was out of calibration or if I was really running that lean. I was not throwing lean codes, so I'm not sure what was going on. 2004 coupe, dyno'd +/- 300/300 with Stinger intake and Magnaflow catback. I don't think numbers would have been that high if the car was really running that lean.
Put LGM LT headers on this weekend, I am going to go back in a couple of weeks to see what change they made.
Thanks for the advice, you are probably right on the money. Have you logged any data since using silicone on the connections? Sorry to hear that you are in the same boat as me. Thanks for the bump.
Nick
If I had to gamble, I would guess that it was the connection at the MAF and the front of the air bridge.
Started loging and it looked like it fixed it. Then I shut the hood and hey the LTFT's stayed the same. Then I opened up and then shut it and they shot right back up again.
Have you contacted Halltech about this yet? I wonder if they can provide some guidance. It looks to me like the bridge is angled wrong so that it won't allow the maf to sit flush without rubbing on the hood...
