C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
ls1 edit shiftpoint need help
Old Feb 22, 2005 | 04:40 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default ls1 edit shiftpoint need help
car is a 2000 a4 it has 3:42 and protourqe 2400 stall. any advice on changing shift points car seems to be sluggish on the freeway after 55mph. i mean real slugish. on the street its fast. what gives. any help would be greatly helpfull. thanks in advance
Old Feb 22, 2005 | 07:09 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
That does seem weird.
Are you sure your converter is locking up on the highway? Try this, after the car is fully warmed up. Check transmission temperature when experiencing the problem at 55-60, and compare that to what you are reading when cruising normally around town. Is it lots higher at highway speed? It shouldn't be.
Here's what the Predator manual recommends for 3.42 gearset:
1-2 Upshift MPH 41
2-3 Upshift MPH 80
3-4 Upshift MPH 130
2-1 downshift 36
3-2 downshift 79
4-3 downshift 118
That should give you a good starting point.
Old Feb 23, 2005 | 09:57 AM
Carbotech Adam
Supporting Vendor
i will try thanks
To ls1 edit shiftpoint need help
