C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
rev-limiter problems
Old Feb 24, 2005 | 09:03 PM
97power's Avatar
97power
Cruising
Default rev-limiter problems
I have been setting all rev-limiters in ls1 edit high at 7500rpms, and trying to have it shift at 7000rpms, but it hits rev-limiter at 6800rpms. No misfires encountered and no check engine light on. This is an a4 with a 3500sy yank converter. Not sure if its edit,pcm or other issue. Any help would be greatly appreciated.
Old Feb 25, 2005 | 01:27 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I can't answer why it limits at 6800rpm, but be glad that it does (unless you have a forged bottom end). Even 6800 is pushing it.
Old Feb 25, 2005 | 03:17 AM
0rion's Avatar
0rion
You changed both tables then? By gear and by temp? I've read where other people have had this problem. I'll have to see if I can dig up the info. That's winding that motor pretty tight. I'm assuming you have quite a bit done to it?
Old Feb 25, 2005 | 08:33 PM
Tom Hall's Avatar
Tom Hall
It sounds like your Tranny might be slipping.
I have a 97 and I can only adjust shift points by speed and not with the RPM settings.
Old Feb 26, 2005 | 12:24 AM
97power's Avatar
97power
Cruising
I am able to set shift points below 6800rpms and shifts fine. When I try to set a shift point at say 6900rpms and rev-limiter set at 7500rpms,the engine at wot hits a rev-limit at 6800rpms. My engine is a forged bottom end and cammed with heads. Sorry for the late reply.
To rev-limiter problems
