C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Throttle Position Sensor - Need Your Help
Old Mar 12, 2005 | 12:27 PM
ZDriver's Avatar
ZDriver
Default Throttle Position Sensor - Need Your Help
I've probably screwed up big time here but we will see. I removed my throttlebody to have it polished to better match the polished supercharger. After removing it I decided to be safe than sorry and removed the TPS because I did not want the polisher to break it off on a polishing wheel. Should have probably figured this was a bad idea when I noticed the special screws that attach it to the housing. But looking at it closely, it can only go on one way and there is no adjustment so off it came.
Long story short, put everything back on, started the car and now when it warms up it wont idle right. After driving a few miles when I come to a stop, the rpm's stay around 1200 to 1800 for about 15 to 20 seconds and then they slowly drop to normal, 700 to 800 rpm's. I think by removing the TPS I've negatively affected my whole tune.
I am not throwing any codes but I can definately tell something is a miss.
Anyone care to voice their opinions or experiences, anyone else removed the TPS and put it back on? The shop manual says the TPS is not a replaceable item and must be replaced as a unit with the throttlebody.
It sure does look nice though.
Thanks in advance for any help or suggestions.
Old Mar 12, 2005 | 04:05 PM
jers98vet's Avatar
jers98vet
I have replaced the tp sensor on my 98 and had no troubles. You are correct in that there are no adjustments. Seeing that youhad the entire tb off the car and high/erratic idle concerns I would check for any vacuum leaks, cracked lines or maybe disconnected ones. Make sure the pcv valve is plugged in too.
Old Mar 12, 2005 | 05:05 PM
Mike Mercury's Avatar
Mike Mercury
don't stay focused on the TP sensor... as the actual problem may be elsewhere.
Old Mar 12, 2005 | 07:28 PM
see5's Avatar
see5
Yeah, I had mine on and off at least six times. Doubt that is it.
Old Mar 14, 2005 | 04:51 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Same thing happened to me when I took the TB off just to polish it up a bit (while installing new bridge, etc.).
I didn't remove the TPS but have the same symptoms. So it's probably not the TPS, but maybe a good cleaning will help? I've triple checked everything else and haven't figured it out yet.
Perhaps it just needs to re-learn the idle? I tried a Shaner TB and the idle was much higher and erratic.
Old Mar 17, 2005 | 01:23 PM
DTSNGIT's Avatar
DTSNGIT
ZDriver,
All of the post have good advise. I've seen this several times. Just disconnect your battery for 24hrs and then reconnect. Let the car idle for 20 minutes with no accessories running. It should relearn the correct idle position if all other parts & hoses are OK and connected correctly.
Mike
Old Mar 20, 2005 | 01:02 PM
ZDriver's Avatar
ZDriver
Thanks for all your help and suggestions. Rechecked everything and re-tightened everything and she's running like a champ!
Thanks again.
Old Mar 20, 2005 | 02:55 PM
jers98vet's Avatar
jers98vet
Thanks again.
Glad everything came out O.K.
To Throttle Position Sensor - Need Your Help
