C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
codes
Old Mar 23, 2005 | 10:38 AM
steves red vette's Avatar
steves red vette
Default codes
When I took the car in to replace the oil sending unit, some other codes came up on the diagnostics. Wondering if you guys know what they are. Please help. Steve
This is what I got from the dealer:
A report on cust states oil pressure fluxuates while running. Possible oil pressure sender???now is stuck 130psi whil driving
4 engine mechanical & related repairs
26 CSCL
33 CSCL
Checked the oil pressure gage inaccurate. Scanned the instument panel cluster. Performed a sweep test. Gage reacts OK. Checked the codes.
Lo SS of cam codes. Not related. Checked the circuit. Found problem with sender. Recommend replacing. Another technician replaced the oil pressure sender and rechecked the oil pressure gage. OK. 40 PSI.
