has anyone had p0171 p0174 fuel trim lean come up after the install ,thanks for any help George
I had a similar problem once, turned out my accordion coupler wasn't attached properly to my air bridge. You should probably check for air leaks and make sure everything before the TB is attached properly.
From: *MIDDLETOWN NY* "I thought I was an OLD-GUY, till I met Charlie"
Sounds like an air leak. Check everything from the MAF to the throttle body once you are sure there are no leaks do an idle relearn. Any leaks after the MAF will let air in that the computer can't sense so the computer will not add enough fuel and you get a lean code . Stop the leaks , do the idle relearn and you should be alright I had zero problems with my VARARAM and this is how I installed it. Hope this solves your problem if not take it to a tuner running lean is NOT good JMHO
This is a problem for some. You can clear codes and keep driving, as it takes quite a few miles for PCM to relearn. However, you really need to get you LTFT in line and recalibrate your MAF for optimum performance. Computer will only go so far on it's own. Mine never threw codes but LTFT were in the 15/17 positive range (should be around 0), meaning the Vararam was causing a lean condition and ltft's were compensating, it ran fine, but was not really correct, for best power.
I tripped a few codes when I first installed my Vararam. I reset the code the first time. When it tripped again I called Vararam. They told me that some Vettes do not have Bosh fuel injectors and the engine is getting to much air for the injectors that were installed. They recommended that I change the filter to one that is more restrictive. They sell them on their website. Before I had a chance to order the filter, I cleared the code for the second time and had no problems since.
Wow ... thats a load of crap! Add a restriction to fix a fuel management problem. I can't beleieve that vararam folks would say something that was so blatanty of base. Get that car over to a quafilfies shop that that will observe O2 switch rates, fuel trims and the like before you go diagnosing around a problem.
I agree, if you want some restriction put the stock set-up back on. Halltech also says add a maf screen (read: restriction) to clear codes on their set-up. I find it humorous.
Wow, samething is happening to me.
Ever since I installed VaraRam CAI, I've had intermitten SES light come on. Got it read and the code is 0171 (Fuel Trim too lean bank 1). It's weird that SES comes on for few days and goes away for several days and comes back on. I don't believe this code effects performance of my Vette, at least I haven't noticed it.
I don't know if this code is related to VaraRam CAI or not. Possible improper install???
Strange thing is, before the VaraRam, I was very rich, I can't imagine VaraRam leaning out that much to throw P0171 code.
Here is a image of AFR before VaraRam, I haven't done AFR check since VaraRam install.
Here's a reason the codes may come and go. The LTFT's have a correction of +/- 20 or 25 and after that if it goes leaner no way to compansate (read: code). The reason for being ok some days is the fact that the lean/rich thing can vary 5% or so day to day depending on weather.
If the PCM doesn't relearn into acceptable parameters, the only way I know of to do it right is a tuner program. You will need to relearn LTFT (long term fuel trims) then recalibrate MAF frequencies to match new ltft's and you get optimum gains as a benifit of proper tune. Some say add a MAF screen or higher restriction filter, but what's the use of putting it on if your going to choke it back down. It can take a couple hundred miles for some cars to relearn.
So Robert your saying you need to have the car tuned after the install of a Vararam? I know nothing of LTFT and I am not even sure I have a tuner close to me.....but I am getting a Vararam soon.
No you don't have to, however to see optimum gains it should be recalibrated. If you throw codes that means your on the edge of the +25%/-25% area that the computer can compensate. Codes may go away with time, or like my set-up and many others you'll never set a code and it'll run fine with gains. When I retuned mine some of my ltft Long Term Fuel Trims (chart rpm x load) were up to +17% (meaning computer was correcting for a lean condition) acceptable yes/maybe, optimum no. It's your call.
I have not seen P0171/P0174 in about 4 days now, hopefully ECU has re-learned itself.
Now, I am about to install TPIS LT headers, will it lean it out even more or would it richen up? I know some folks get leaned out with LT headers and others get richened.
