C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
another predator question
Old May 11, 2005 | 09:54 AM
gsxrjack's Avatar
gsxrjack
Default another predator question
i got an email tune from runningwiththedevil.com and installed it in my predator....question is, do i still have the original predator performance tune AND the email tune or does the email tune overwrite the predator performance tune....
2nd part, if i still have both tunes in there (email and performance tune) how do i select either one...
thanks
Jack
Old May 11, 2005 | 10:10 AM
Mike Mercury's Avatar
Mike Mercury
on my Predator model (1999-2003) you can't have two "tunes" stored. It's always the original file - and the Preformance tune (or a custom one - that now becomes your new "performance tune")
Old May 11, 2005 | 11:03 AM
lar66BB's Avatar
lar66BB
Default program
Each time you change something it writes over the installed program.
You can not have two different in your cars pcm. You could have
diffent set ups in your pred. maybe? Not sure you would have to
ask the tuner. I use the Vinci and it has different cam profiles
you can choose from, which in turn changes the tune., ie more
timing and fuel ect.
Old May 11, 2005 | 11:20 AM
gsxrjack's Avatar
gsxrjack
thanks, now hopefully i saved the original performance tune, that way ill be able to reinstall it over the email tune if i want to see the difference...correct?
Old May 11, 2005 | 08:10 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Should.
I have every tune James ever sent me on the hard drive of my laptop.
I can simply select one upload it into the Predator and from there to my car's PCM.
To another predator question
