C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Hp tuner...
Old May 24, 2005 | 10:45 AM
Z06_Performance's Avatar
Z06_Performance
Default Hp tuner...
Can I do this alone at home? What can I expect? And if I went to a dyno to get it pro tuned? Thanks! Z06 lg long tubes, gx3 cams, fast manfiold, borla stingers..
Old May 24, 2005 | 12:04 PM
slo-vette's Avatar
slo-vette
You can do this at home with the guides available online. It just depends how much time you want to spend on the tune. I will say you can get overwhelmed very quickly if you intend to do the full tune. Do you already own HP Tuners? If not and someone in your area can do a full tune, not just WOT tune, I'd let them do it. Did I mention it is very time consuming?
Check out ls1tech.com in their PCM forum for some great stickied posts.
Old May 24, 2005 | 01:53 PM
Z06_Performance
I have so much time on my hands it isn't even funny..
Old May 25, 2005 | 01:02 PM
DT's Avatar
DT
Howdy!
I use HPTuners - I'm can turn a decent wrench, but pretty much a novice at tuning. I just read as much as I can - go to all the tuning forums on the various LSx sites, plus HPT has an excellent forums as well. There's a number of "foreign" concepts I still havent' completely grasped, but I'm still working at it!
They've been excellent about releasing new revisions, listening to the owners and integrating new features (such as wideband). The interface is good, simple to use - however, the tuning itself can be pretty complex - It's a got an excellent data logger I've used to based my tune on, but for that _fine_ level of tune, you should really get a wideband (like a WB Commander) setup.
The nice thing about doing it yourself:
You learn about the car, which I find pretty interesting, and DIY is much more satisfying (though as mentioned...time consuming )
You own the tune, you can have dozens of tune files (and a backup of your stock cals as well) - so no ECM lockout, or unknowns.
If you're doing incremental upgrades, the cost of HPT will be cheaper vs. multiple trips back to the tuner (which could also be a PITA depending on their location, my closest is 2 hours away).
You can also have your tuner USE your HPT which is nice, then you get your .bin files and see what was done and learn even more!
FYI, with a GX3, FAST, LT's you're probably leaving TONS of power on the table, plus I would suspect the car isn't running nearly as smooth as it could (surprised it's running at all!)
Old May 27, 2005 | 12:01 AM
Z06_Performance
Well what should I add to the setup.. Remember I dont want to be FI I am NA.. All Motor!
Old May 27, 2005 | 10:10 AM
Z06_Performance
Old May 27, 2005 | 08:20 PM
Z06_Performance
Anyone?
Old May 27, 2005 | 09:09 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
I just got HP tuners today and I have been playing around with it. Very nice software . I have the version 1.7.
To Hp tuner...
