C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
My tune....
Old May 27, 2005 | 11:17 AM
Phil97SVT's Avatar
Phil97SVT
Default My tune....
I have been a dog chasing its tail for the last 2 weeks trying to get this tune right. Initally I tuned the car with some bad tables. After I switched back to the stock tables and recalculated a couple of others I went back to VE Tuning in SD mode. A couple of days passed and after 3-4 drives the car was +-3% error in almost every cell. I went back to non SD tune and the car ran like garbage, the LTFT were off and the car wanted to break up for some reason. Looking at the logs the MAF data was corrupt. The data was all over the place. We pulled the MAF and sure enough it was dirty.
I cleaned the MAF and went back to SD tune to make sure it was right and it was dead on. So the next tune I used all of the data from the past 8 sessions to create a scatter chart to plot the corrected MAF data and sure enough the orginal tune was off. I uploaded the program with the calibrated MAF up to ~8500 and the car idles and drives like a champ. There is a noticeable difference in part throttle to WOT transition, part throttle 1200-1600rpm driving(no surging), and all of the trims are +-1. Now we need to go back and tune the car to WOT. If you guys got any questions let me know.
Phil
Old May 27, 2005 | 01:37 PM
LivinTheDream's Avatar
LivinTheDream
Phil
An accurate MAF curve is essential if you're going to SD tune, then plug the MAF back in. People like Marcin who have spent many hours uploading Excel calculators to do the dirty work for you are a great value to the community. And there are guys like Will who uploaded a calculator for us 97-99 guys who have a secondary VE table when the car goes into SD mode; it builds a smooth full resolution primary table for you using the secondary's half resolution.
My 98 has a stock MAF, but it turns out to have the Monaro's curve. If I hadn't been building this curve as I SD tuned, the STFT's would have skewed when I reenabled the MAF. Like you, I have a sweet part throttle tune and hardly had to touch anything PE-wise to get good WOT power with almost no KR at the dyno. Made a believer out of me.
Old May 27, 2005 | 04:05 PM
slo-vette's Avatar
slo-vette
Thanks Phil! Can you post your VE table? I'm curious what it looks like. Also while in open loop SD mode how do you dial in the VE table at high RPM values if they say to keep it under 4k?
When you state calibrated MAF, do you mean the MAF tables you just tuned or do you mean an aftermarket MAF unit?
Old May 27, 2005 | 04:42 PM
Dixit's Avatar
Dixit
slo-vette, by calibrating the MAF, he means that he logged the MAF hz and the Dynamic Airflow PIDs and then used that data to get the MAF hz table inline with correct reading. For each Hz the MAF reads, it translates that into x.xx amount of air it read. Now if that table is off, then the MAF is incorrectly reporting the air. So calibrating to the closest possible value is key.
Dixit
Old May 28, 2005 | 12:51 PM
Phil97SVT's Avatar
Phil97SVT
Couple of things..
1) You dont need a MAF to SD tune
2) Marcin's calculator uses MAF frequency vs Dynamic Air(Averaged data)
3) I made pulls up to 7000 to tune the VE table and averaged the high end
4) My maf has custom ends on it that have been bored out to 90+mm
- Used the logged data MAF vs DA and used that data.
Phil
To My tune....
