C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
WTF is wrong?
Old Jun 4, 2005 | 05:00 PM
baddvette98's Avatar
baddvette98
Default WTF is wrong?
My 98 has a bad misfire in cyl#7 changed the coil, plugs, wires that did'nt fix it, and all the grounds look fine! The car also backfires! What the hell is wrong?
Old Jun 4, 2005 | 05:50 PM
lar66BB's Avatar
lar66BB
Default misfire
Take a compression check on that cyl. you may have a broken
valve spring, or bent pushrod.
Old Jun 4, 2005 | 05:56 PM
baddvette98
I will tell the shop on Mon. to check the com. Thanks
Old Jun 6, 2005 | 11:54 AM
XotiK ZO6's Avatar
XotiK ZO6
I would take another look at the shop I working on my vette. I would think that would be the next logical step, and something they would have recommended.
Good luck and let us know what they find.
Old Jun 6, 2005 | 02:14 PM
C5forFun's Avatar
C5forFun
yah thats not good when a shop starts replacing thing without knowing why!
I would hope that they plugged it in to a scaner and tested the ignition first, and a leak down wouldn't be a bad idea either.
good luck
Old Jun 7, 2005 | 09:43 AM
dvettetech's Avatar
dvettetech
Swap the injectors # 5 to say #2 and see if the problem moves. If yes... you'll know what to do
Old Jun 11, 2005 | 12:29 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Dont wait
Go to a local parts store (Autozone, Pep-Boys, Napa) but a compression tester and do it your self. Its very easy.......why wait till monday when you can check that..........I see a bad ring on the piston.....Blow By
To WTF is wrong?
