C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
custom 04 A4 Predator program
Old Jun 19, 2005 | 10:15 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Default custom 04 A4 Predator program
I have an 04 A4, and a predator tuner. I think Im ready to play around with the custom tune. Any ideas on where to start, or a custom program that someone is using that works well for them?
2004 A4 dual cone air cleaners, otherwise stock.
Old Jul 7, 2005 | 02:37 AM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
I like to run my shift pressure at +15 and my shift time at -15. Then I set my fans to come on 5 degrees cooler.
Have Fun,
AZC5
Old Jul 13, 2005 | 10:05 AM
RockyL32's Avatar
RockyL32
Thanx AZC5 Ill try that.
Old Jul 14, 2005 | 10:00 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
At one time, my car was setup exactly the same as yours. As verified on a dyno, the optimum settings for my engine (on 91 octane, at sea level) were:
  • WOT Fuel 2K-4K = -5%
  • WOT Fuel 4K-7K = +6%
  • WOT Spark 2K-4K = +2%
  • WOT Spark 4K-7K = +7%
Note that the +/- for fuel is counter-intuitive (minus means richer).
These tweaks were performed on the stock (not "Performance") tune. HTH!
Old Jul 16, 2005 | 05:56 PM
RockyL32's Avatar
RockyL32
THANX BW1 that is great info
Old Jul 25, 2005 | 09:45 AM
RockyL32's Avatar
RockyL32
I adjusted the above mentioned settings and it seems to have made a pretty significant diference. Thanks all
Old Sep 4, 2005 | 04:16 PM
C5Aggie03's Avatar
C5Aggie03
Can you elaborate just a little bit more on this? I'm curious about this predator tuner and might consider getting on to help out my A4 2.73 situation. Thanks.
Old Sep 4, 2005 | 05:30 PM
Mike Mercury's Avatar
Mike Mercury
just for clarification; Predator uses the phrase "Custom Tune" - not to mean that one has varied from the supplied Performance Tune.
Instead, their use of the phrase "Custom Tune" is when you are sent a customized file via the internet; you load it into your Predator, and then into your PCM. It's a file that was generated by either Diablosport or your Predator seller that has specifics to do with your car and it's unique mods.
Just to clear up any confusion (if there was any).
To custom 04 A4 Predator program
