C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
C5 Speedometer Calibration
Old Jun 30, 2005 | 02:06 PM
Since 53's Avatar
Since 53
8th Gear
Default C5 Speedometer Calibration
I have been scouring the Internet for days searching for the answer to this question to no avail:
Is there any ‘do-it-yourself’ way to perform a Speedometer Calibration on a C5 Corvette without having to purchase a $500+ ‘Scan and Tune’ software package or a $300+ handheld unit (like a Predator, etc.)? From what I have found so far, it looks like the key is modifying the Tire Height and/or rear end gear ratio in the PCM. Any of you ‘Scan and Tune’ guru’s out there found a more cost effective/easy way of doing this? Thanks in advance. . .
Old Jul 1, 2005 | 12:25 AM
Dixit's Avatar
Dixit
Cant think of any way. If you have someone near you that has an HPTuner and has a license for that year, ask him to change it for you and take it our for a few beers.
HPTuners dont license down to VIN, just model year.
Dixit
Old Jul 2, 2005 | 06:16 PM
Mike04's Avatar
Mike04
you can't do it unless you have a programer or take it to a tuner. The tuner would charge far less than a programer if all you are doing is changing gear ratio or tire size.
Old Jul 3, 2005 | 09:38 PM
DTSNGIT's Avatar
DTSNGIT
If you ever get down to SC I'll take car of it for $75. I'll probably be in Richmond the last week of Sept and could help you out. Email me at: dtsngit@bellsouth.net if you want to discuss.
Mike
Old Jul 4, 2005 | 11:11 AM
Mike Mercury's Avatar
Mike Mercury
since changing rear axle ratios on the C5 does not affect the speedometer... the only route is to alter tire heigth parameters.
I think the GM Tech-Tool 2 allows this. If so; then my local Chevy dealers charge $75 for a reprog.
Also, there's the forum vendors "$99 mail order tune"; but you would need to send them your PCM (your C5 will not be driveable during the process)
Old Jul 5, 2005 | 12:57 AM
Since 53's Avatar
Since 53
8th Gear
Default C5 Speedometer Calibration (continued)
First of all, I'd like to thank Dixit, Mike04, DTSNGIT, and Mike Mercury for your expeditious replies.
In regard to Mike Mercury's reply however I need some clarification on how this thing works. I have no first hand knowledge in this area, so I must give you the benefit of the doubt that what you are saying is correct. I have been told that the circuitry that sends the pulses to the PCM that is eventually translated to the analog voltage which moves the needle on the speedometer; is in the rear end. If that much is true, then why doesn’t changing the rear end gear ratio not change the speed of the electromagnetic pick-ups in the differential (unless of course if the pick-ups are actually tied to the rear axles some how). Please share additional details if you know. Thanks. . .
Old Jul 6, 2005 | 12:19 AM
gojo's Avatar
gojo
The Speedometer is driven off the wheel sensor, so it is independent
of any gear change, but will change with tire size.
The Transmission is driven from the VSS, and uses a reluctor on the
ring gear.
Old Jul 6, 2005 | 10:36 AM
Since 53's Avatar
Since 53
8th Gear
Thanks for the info 'gojo'! Pardon my ignorance (haven't been a C5 owner for that long) but what exactly is a "VSS" and a "reluctor"? Again I apologize, but I'm a Computer Geek not a Gear Head.
Old Jul 6, 2005 | 04:46 PM
gojo's Avatar
gojo
VSS = Vehicle Speed Sensor.
The relucter is a sensor attached to the ring gear that, as it rotates, sends pulses to the PCM (computer). Those pulses are used to determine "speed" and cause the trans to shift.
This is why when gears only are changed, in a C5, the speedometer will be accurate but the trans shift points will have changed.
To C5 Speedometer Calibration
