C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Predator Question
Old Jul 12, 2005 | 09:21 PM
jpc0011's Avatar
jpc0011
Default Predator Question
I changed shift pressure to +15 and shift time - 15. Still not chirping the tires? I do have runflats w/ approx 3600 miles? Is it the tires?
Old Jul 30, 2005 | 10:53 PM
jhiiidoc's Avatar
jhiiidoc
Are you running 2.73's or 3.15's? With the 2.73's, I'd say you'd be hard pressed to get the tires to chirp even with those settings. You might try disabling the Torque Reduction, but beware of tranny damage.
My recommendation is drop for 3.42 or 3.73's. I installed 3.42's and with the car in Comp mode, the car will break loose and try to go sideways when it shifts into 2nd under full throttle. My mods are mild (ZL6 Powerflo Package from SLP) but man what a ride. I only tuned the pressure +5% and the timing -10%. I did turn off my Torque Reduction. (nino malo ). Good luck
