C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Help w/ Predator
Old Jul 14, 2005 | 08:28 AM
jpc0011's Avatar
jpc0011
Default Help w/ Predator
I have an 01 coupe. Only mods are blackwing and corsa indy w/ x pipe. Should I just use the predator download, or any recommendations on changing parameters. Thanks
Old Jul 14, 2005 | 09:48 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Without benefit of a dyno printout showing a/f ratio, any parameter changes you make will just be a guess. Try starting out with the Predator's built-in "Performance" tune and see what you think.
Old Jul 14, 2005 | 11:37 AM
jpc0011's Avatar
jpc0011
Thanks. I did change shift pressure and time but still no wheels at gear change.
To Help w/ Predator
