C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Scan Tools
Old Sep 13, 2005 | 07:03 AM
V8_Club's Avatar
V8_Club
Default Scan Tools
Hi Guys,
I have a question with regards to the above , is the scanner included in HP Tuners as good as AutoTap/EFI Live ?
Old Sep 13, 2005 | 12:49 PM
V8_Club's Avatar
V8_Club
ttt
Old Sep 13, 2005 | 05:43 PM
Gordy M's Avatar
Gordy M
For non-OEM scanners, EFILive is the best and HPTuners is very similar. Autotap is a distant last. Without getting into details, you want a scanner that can cover all the GM enhanced pids, scan at a rate of at least 20 cycles per second and preferable 40 per sec. The autotap scans at 10/sec. There are 11 computer controllers in the C5 attached to the OBD2 port. When you use a scan tool it is logging on the starbus (CAN for 04 and up) to get the info. Higher the scan rate better the quality of information. Best OEM scanners are Tech 2 and EASE. Both have modules to scan all 11 controllers in C5. FWIW
To Scan Tools
