C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
2001 w/Computer or Wiring Problems...
Old Sep 13, 2005 | 08:58 PM
ThePatriot's Avatar
ThePatriot
Default 2001 w/Computer or Wiring Problems...
OK, it all started out with what felt like a TPS problem. From idle or off-idle she would stumble or do nothing at all and suddenly send the tires up in a blaze of smoke. A couple days later she started sputtering and missing badly. Then, for no apparent reason she would straiten up and run like a champ.
I found several articles on the forum about ground wire corrosion which helped quite a bit, thank you to those guys. But she's still acting up and throwing codes. Below are several days worth of codes. After recording these I cleared them.
While checking and cleaning connections I unplugged the main computer as well as the one below the carpet on the passenger floorboard. After reconnecting everything including the batter it wouldn't crank at all. I eventually disconnected the harnesses from the computer under the passenger floorboard and it finally would crank and start. I drove her for a few days but when I parked her yesterday she went back to that computer thing where she won't crank at all.
Idea's?
She's dead right now and I'm getting the itch.
OBD II
Diagnostic Trouble Codes: (DTC)
2001 Corvette, Recorded September 07, 2005
A6 SCM (1 Code)
B2605H Seat Front Vert. Position Sensor Failure
10-PCM (3 Cods)
P0131C HO2S Circuit Low Voltage Bank 1 Sensor 1
P0151H Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0174H Fuel Trim System Lean Bank 2
2001 Corvette, Recorded August 29, 2005
10-PCM (3 Codes)
P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0155 HO2S Heater Performance Bank 2 Sensor 1
P0174 Fuel Trim System Lean Bank 2
2001 Corvette, Recorded August 28, 2005
10-PCM (2 Codes)
P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
2001 Corvette, Recorded August 24, 2005
10-PCM (1 Code)
P1514H TAC System MAF Performance
60 IPC (6 Codes)
U1160H Loss of Communications with LDCM
U1040H Loss of Communications with TCS
U1016H Loss of Communications with PCM
U1064H Loss of Communication with DCM
U1088H Loss of Communication with SDM
U1176H Loss of Communications with RFA
80 Radio (3 Codes)
U1064H Loss of Communication w/ DCM
U1096H Loss of Communications with IPC
U1016H Loss of Communication with PCM
AO-LDCM (7 Codes)
B2208H Right Window Down Switch Fault
B2282H Battery #1 Fault
B2284H Battery #2 Fault
U1255H Serial Data Line Malfunction
28TCS (2 Codes)
C1278H TCS Temporarily Inhibited By PCM
C1293H DTC C1291/C1292 Set Curnt/Prev Ign Cycle
