C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Shift Pressures ?
Old Sep 14, 2005 | 05:40 AM
V8_Club's Avatar
V8_Club
Default Shift Pressures ?
Going forward with my tuning learning Next point on my agenda is Shift Pressure . How do we do this ? Best Practices / recommendations
P.S. FWIW I am compiling a how to document for LS1 Edit beginners like me. This and all my previous findings are going into the same. It is shaping up nicely I might add. Thanks to help from members. AZC5 is one major contributor till now.
Old Sep 15, 2005 | 10:34 PM
LivinTheDream's Avatar
LivinTheDream
I'm not a fan of changing shift pressure though it's popular with many. It seems too delicate an adjustment--just my opinion. Have you tried just changing the shift times to see if that suits? I've found I can get really crisp, firm shifts where I want, when I want by working that table. This combined with a lot of work in the part throttle shift table has my 98 behaving like it has a shift kit.
Old Sep 16, 2005 | 05:15 AM
V8_Club's Avatar
V8_Club
No not yet. See I'm in the gathering info stage as of now. Interesting point though.
Old Sep 25, 2005 | 02:23 AM
V8_Club's Avatar
V8_Club
Ttt
Old Oct 7, 2005 | 01:42 PM
V8_Club's Avatar
V8_Club
Ttt
Old Oct 13, 2005 | 01:17 PM
V8_Club's Avatar
V8_Club
300+ views and only one response ?....... Come on guys lend a hand to a novice or should I say a brain cell or two
Old Oct 13, 2005 | 01:24 PM
WKMCD's Avatar
WKMCD
I doesn't take much pressure for me to shift. Sometimes shifting into 6th can take a little more..There, hope I've been helpful.
Old Oct 13, 2005 | 01:39 PM
V8_Club's Avatar
V8_Club
Hmm I guess my question wasn't clear. What I meant was changing values in the PCM for shift pressures in an A4 car. This is done to get firmer shifts without installing a shift kit I would like to know what values people are using etc
Old Oct 13, 2005 | 05:31 PM
BHP's Avatar
BHP
If you are using LS1Edit there is a table calibration in the manual that increases shift firmness with increased throttle.
Old Oct 14, 2005 | 06:38 AM
V8_Club's Avatar
V8_Club
This I know my question is , what are peoples settings with regards to the same ? Best practices ? Best Shift Feels at what setting ?
Old Oct 14, 2005 | 03:50 PM
JEEP/C5's Avatar
JEEP/C5
E-mail Mike Mercury, he knows all about the predator and shift points and pressures. Also try looking in the CF for other post that my help you. I have seen some and it seem like they suggested -5 to -7 on times and +5 to +7 on pressures? This it the next on my list of "TO DO's" too.
Old Oct 14, 2005 | 04:58 PM
V8_Club's Avatar
V8_Club
Thanks but I'm using LS1 Edit/Hp Tuners so I would like to know how the above translates over there ? Hmmm lets see I read somewhere that the Predator only allows variations within +/- 20% so on the scale on 1-10 that would correspond to an increase of either 10% or 14% ? Am I on the right track ?
Old Oct 14, 2005 | 10:15 PM
TLKSCHP's Avatar
TLKSCHP
My tranny isn't stock anymore but I did cut the shift time by 50%, line pressure on mine is controlled by vacuum
Old Oct 18, 2005 | 05:07 AM
V8_Club's Avatar
V8_Club
Ttt
Old Oct 18, 2005 | 10:21 AM
HPTuners's Avatar
HPTuners
Supporting Vendor
For the street my preference is to have the trans complete the shift in 1/4 second.
Anything more is slip, anything less is bind.
It really is a matter of preference unless you are making a lot of power and burning up clutch packs. At that point you would need a trans with upgraded aftermarket parts anyway.
Ken
Old Oct 18, 2005 | 10:38 AM
V8_Club's Avatar
V8_Club
Ken
Does adjusting shift pressure affect shift time ? Or is your response related to Desired Shift time ?
Also so you set desired shift time @ .250 ? Do you do that for the whole table or do you set it gradually ?
Old Oct 18, 2005 | 11:24 PM
HPTuners's Avatar
HPTuners
Supporting Vendor
Increasing the shift pressures will decrease the shift time. The shift time tables are for "self learning". Some guys drive harder so the VCM will increase the pressure on its own if the shift time falls below those table values.
I set the shift time tables to .250 and adjust the shift pressures for what I want that day. The Wife is not as fond of the firmer shifts
Ken
To Shift Pressures ?
Old Oct 18, 2005 | 11:38 PM
V8_Club's Avatar
V8_Club
Thanks Ken. So how do you go about increasing the pressure ? in 10% increments accross the board until you get the feel ? or do you have an example ?
I'm sorry if I'm asking too much but this tuning thing is GREAT
Regards,
Nabil
Old Oct 21, 2005 | 03:19 PM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
I have found it to be the other way around.
If shift times are set lower than the tranny can physically shift in(ie. 0.00), the transmission will apply full line pressure to the next shift in an effort to shift in 0.00 seconds. Which is impossible, causing the shift to always be at full line pressure.
I would personally use .163, as that is the lowest "shift time" from the factory. Shift pressure on the other hand is very subjectional. I would start with little increases in your shift pressure, until you find a setting you like.
Good Luck,
AZC5
Old Oct 21, 2005 | 03:35 PM
V8_Club's Avatar
V8_Club
Thanks AZ. But how little is little ? 10 % ? 5 % ?
