C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
C5 Water Pump Replacement
Old Oct 9, 2005 | 10:31 PM
On the Fence's Avatar
On the Fence
2nd Gear
Default C5 Water Pump Replacement
Are water pumps an item that fail more often than they should on the C5? I have been told that they last up to about 30,000 miles and then are a bitch to replace. Also, when they fail, they have been know to leak on the distributor resulting in big $$$ to repair because it shorts out the ignition system. I am considering a 2004. Thanks for the imput.
Old Oct 10, 2005 | 05:11 PM
Scooter70's Avatar
Scooter70
You're confusing LT1 and LS1 with the above comment. The LT1s are the ones that can leak on the Optispark (the "distributor"). I've heard of no issues with premature waterpump failures on any LS1 powered vehicles.
-Matt
Old Oct 11, 2005 | 08:51 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Waterpump
[Scooter70]You're confusing LT1 and LS1 with the above comment. The LT1s are the ones that can leak on the Optispark (the "distributor"). I've heard of no issues with premature waterpump failures on any LS1 powered vehicles.
-Matt
________________________________________ ____________________
I just replaced mine over the weekend. 1998.....116,000 miles. Not much different from any other waterpump. I ended up removing the throttle body to make it easier to scrap off the gasket on the engine block. I also used a "paint & gasket remover" spray on the gasket. Spray it on....let it sit, scrap it off. I replaced the serpentine belts which also had 116,000 miles on them.
Now I'm all ready for "Vettes on the Boardwalk" in Ocean City, Maryland this weekend
Old Oct 11, 2005 | 09:30 AM
WKMCD's Avatar
WKMCD
I had to replace mine at 32k. No problem to replace at all. Just wrote a check.
Old Oct 11, 2005 | 10:03 AM
xlr8shn's Avatar
xlr8shn
Your statement is accurate for LT1 C4's and LT1 F-Bodies. The problem is when the water pump bearing goes and it leaks out the "weap" hole at the bottom of the pump which is directly above the opti.
I have replaced several optisparks and replaced a waterpump with an elec Meziere... Not too tough IMO.
THANK GOD C5's DO NOT HAVE THIS PROBLEM - thanks to coil packs per cylinder
To C5 Water Pump Replacement
