C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Steering Recall
Old Oct 18, 2005 | 08:51 PM
mart's Avatar
mart
5th Gear
Default Steering Recall
Had steering recall done and temp runs at 230 degrees at idle . Fans turn on at 230 and shut down at 217. Engine used to run at 192 to 205. Anyone have similar experience? Car is a 2003 Z06.
Thanks, Mart.
Old Oct 19, 2005 | 11:38 AM
EHS's Avatar
EHS
Thanks, Mart.
Didn't notice that, but the recall includes a free PCM flash "upgrade" as well. My car ran like crap afterward.
Old Oct 19, 2005 | 05:09 PM
mart's Avatar
mart
5th Gear
Got any ideas on how to get PCM back to performance settings?(Without getting the dealer involved to mess up things again)
Old Oct 31, 2005 | 04:26 AM
Shylor's Avatar
Shylor
What steering recall? Or did you mean the Column Lock recall?
Old Oct 31, 2005 | 04:37 AM
EHS's Avatar
EHS
That's what I assume he meant.
****BREAK
Only way to get the car back to the "old" settings is a custom tune.
I asked the dealer -- they (GM) don't allow "rollbacks," apparently.
Old Oct 31, 2005 | 01:05 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
Both HPtuners and EFIlive have the original tunes available via a website. I have EFIlive's on my laptop at home I could email to you. The trick is to find a shop that could reflash your PCM or buy the tuning cable. Send me your email if you want me to send the EFIlive file.
Noe
noe_ortiz@yahoo.com
Old Nov 1, 2005 | 06:50 PM
game on's Avatar
game on
Mart,
Sounds like you pcm was modified prior to the dealership recall.
I had my pcm modified prior to the column lock recall. The dealership re-installs the stock program with the column lock recall which results in higher coolant temps as you describe. If you have a 6 speed, it also gets rid of the skip shift fix on the pcm mod.
Try to find the shop that made mods to the pcm. Might save you money in getting back to cooler temps etc as tuners generally save mods by customer/car.
To Steering Recall
