C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Help: Code P0300 H C
Old Oct 22, 2005 | 12:56 PM
GS348's Avatar
GS348
Default Help: Code P0300 H C
I believe this code to be a misfire. I replaced the plugs and checked the wires befor I reinstalled them. The code remains and the car still runs rough...any ideas?
MJP
Old Oct 27, 2005 | 11:44 PM
JR_VET's Avatar
JR_VET
Default be a misfire
MJP
Question1. have you placed some long tube header on your car? If so you need to check the o2 sensors to ensure they on right, the back o2 sensors for the pass side plug in on the driver side and the other on the pass side. break out your books a make sure they properly installed and not close to the headers. clear code and try it again.
Old Oct 28, 2005 | 06:26 AM
Gatzer's Avatar
Gatzer
Any new mods added to the vehicle?
A cam will also throw this code.
Old Oct 28, 2005 | 08:55 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
When did it start? Any obvious fouling of plugs? Do you have access to a scanner? That would let you look at misfire counters which would point you to offending cylinder(s).
Old Oct 30, 2005 | 05:07 PM
leojnknsC5's Avatar
leojnknsC5
Default Misfire codes
You can get a misfire code from either a spark plug that doesn't fire or an injector that isn't allowing enough fuel or allows too much fuel into the cylinder. If you get the misfire code without a "lean fire bank1/bank2" code or "rich fire bank1/bank2", it's probably not an injector.
To Help: Code P0300 H C
