Need help with a check engine light
When I returned to the staging lanes, I check for codes and there are't any except 2 HVAC codes, which I didn't write down because I didn't think they were relative.
What do you think, 4th round went without a hitch? Drive home was OK as well? I guess the question is, what can trun on the CE light, without throwing a PCM code? Info on car are in my sig.
Thanks for your time
Ed
Also though being it was tuned they could have turned OFF some error codes or tuned out functions like misfire or knock and you would never know what happened since the codes are commanded never to trip on.
You need to do a indepth PCM scanner recording and see what may be out of line
