C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Tech II
Old Nov 25, 2005 | 02:59 AM
Cscokd's Avatar
Cscokd
Default Tech II
Does anybody know what features or options can be enabled or disabled with a Tech II tool? Or is there some other tool that can do this? Like I've heard that you can disable the F45 shock system. I'm also wondering if there is a Active Handling option that can be enabled? My '98 has a front mounted EBTCM but did not come with Active Handling which was an option on my late '98 C5. I read through the operators manual for "Ease" PC based Tech II software but did not see anything that might do any of these things.
John
Old Nov 25, 2005 | 10:37 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
John
John,
To my knowledge only the TECH II can turn off F45.
Charlie
Old Nov 25, 2005 | 01:56 PM
Cscokd's Avatar
Cscokd
Thanks Charlie
John
Old Nov 26, 2005 | 08:21 AM
78Vette-SA's Avatar
78Vette-SA
I forget where I saw it but there is a simple DIY "Mod" to diasble the F45. I'll look around and see if I can find it somewhere.
Old Nov 26, 2005 | 10:49 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
This is not an all-inclusive list, but will give you an idea of what can be addressed via Tech-II.
HTH!
Old Nov 26, 2005 | 12:44 PM
78Vette-SA's Avatar
78Vette-SA
Dumb question but does anyone know if a TechII can handle rear gear changes on a 97A4. I have HPTuners which does it for all 98-04's with the package I have. Does not support all 97's though.
Old Nov 26, 2005 | 11:38 PM
Cscokd's Avatar
Cscokd
HTH!
Thanks Bob! I noticed under the BCM menu it shows * Active Handling (RPO JL4). Do you think this would turn on the AH option on my late '98?
John
Old Nov 26, 2005 | 11:56 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
John,
There is a lot more to AH than just toggling a bit in the BCM:
http://corvetteactioncenter.com/tech...ehandling.html
You would obviously need the tc/ah switch wiring, plus all the sensors noted in the article. OTOH, the RPO code shown is the correct option for 1998 model year. It might be worth a try, unless someone can chime in with the definitive answer.
-Bob
Old Nov 27, 2005 | 12:40 AM
Cscokd's Avatar
Cscokd
John,
-Bob
Bob, I'm betting that since this was a production car with front-mounted EBTCM with AH offered as an option, then the only thing I would need to do is change the switch harness on the console and enable it. I doubt they had time to cost reduce by removing sensors and such. I bet all the sensors are there. I will start looking into this just to see what's there. I wish if someone else has already looked into this that they could offer some insight on this option.
John
To Tech II
