Need Input
Need input from tuning gurus, here is the background. Just got the car back fron Installing Vararam, Kooks LTs,Xpipe,High Flow Cats,Z Catback ,3600 converter & 3.42 rears.
No codes/issues from Converter. Also I input the new rear in Hp & it auto scaled shift tables accordingly. I did some other changes as well , Reduced Tranny TM, lowered fans , Copied Main Octane to Low Octane , Firmed up shifts a bit , Deleted Engine TM , shift times lowered to .200 , WOT % TPS changed , COT disabled , Max enige TQ changed .
Car was running a-ok. Did a scan and found as expected that my LTFTs & STFTs were way off. Zero Knock Retard .
So after a lot of research , I put the car in SD mode ( MAF fail = 0 , NO MIL for MAF Codes 101,102 & 103 ). Then scanned after a RESET . Trims came down but needed a bit fine tuning. So I Tweak the VE table using the following formula :
LTFT + STFT = Total Change .
New VE value = Existing Value + ( Total Change / 2 )
I upload the same , reset the fuel trims . 100 miles later ... ( and after my new rear break in
) I do a scan . For reference , Scan parameters are min cell count 10. Results :
All LTFT values logged are within +-4% EXCEPT one where the result is +6 ( Cell 2.0/30) Count was 136.
All STFT values logged are within +1to-3% .
ONE degree of Knock Retard in the following Low load cells :
2.0/.60 15 count , 2.2/.52 5 count , 2.2/.56 3 count , 2.2/.60 5 count .
Car did not go into PE since max rpm was 3.2. Also I have set up my PE TPS to start at 80% hence I know for sure.
My questions are as follows :
1- Should I further tweak my VE table to get that ONE cell down into the ideal +-4% range ?
2- Should I reduce timing in the cells I got KR or it is not required for one degree in low load cells ?
3- Given the good state the car is currently running is SD mode , would you suggest I re-enable the MAF ?
P.S. The VE tuning via Narrow band is only temporary to ensure the car is running ok. I will get my wideband hooked up soon then will tune the same via AFR error & also MAF error ( if I choose to reenable the MAF ).
Let me hear what you guys think
Hold off until you get your WB installed. Make sure you buy a good one with RPM and datalogging.
