C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Lean Codes after Haltech Install
Old Dec 15, 2005 | 06:11 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Default Lean Codes after Haltech Install
I put a Halltech stinger on my 04 CE Coupe about 300 miles ago. I keep popping lean codes about every other time I drive it...
The MAF still has the stock screen...only other mod is a catback with an X-pipe.
I checked all the brackest to make sure everything was nice and tight and no air was getting in anywhere...
Is there anything short of getting a tune that will stop the lean situation?
Tks
Peace
Willfulone
__________________
..................Click for
Old Dec 15, 2005 | 09:40 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
A pretty common condition. o3's, 4's are more prone to the issue. I had to get a tune to correct the problem.
Old Dec 17, 2005 | 01:51 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
You've driven the car plenty for the PCM to have adjusted to the increased airflow by now. I know you said you checked everything for tightness, but there really can't be any other cause for that code than unmetered air entering somewhere downstream of the MAF. I have to wonder if you have a crack or leak somewhere.
Try this...
Get a pump applicator (like an empty bottle of detailing spray) with windshield washer fluid and spray it onto the body and seams of the air bridge and coupler (while the engine is running). This should confirm or eliminate the possibility of air entering there. If you do find a leak, and a small amount of liquid gets sucked in, it should be harmless - windshield washer fluid is primarily a mix of methanol and distilled water.
GL!
Old Dec 17, 2005 | 06:12 PM
CCA Corvette Parts
Nice...Tks I'll give it a shot...
Peace
Willfulone
Old Dec 18, 2005 | 07:45 AM
WKMCD's Avatar
WKMCD
Maybe it's a tumor.
To Lean Codes after Haltech Install
