C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
PCM Learning
Old Dec 29, 2005 | 08:25 PM
chriscostas's Avatar
chriscostas
Default PCM Learning
I have a 2002 Coupe MN6, with the Borla Stinger Exhaust and Halltech SSM CAI will the computer adjust itself to even out the air/fuel ratios and perform better? And what can I expect in horespower and throttle response difference? Thanks everyone!
Old Jan 5, 2006 | 01:10 AM
EHS's Avatar
EHS
Yes, the PCM will relearn after about fifty miles.
You can expect better performance.
Old Jan 5, 2006 | 04:23 PM
Gordy M's Avatar
Gordy M
A PCM relean can take as little as 50 miles and as long as 200+ miles. Some of the parameters are updated ever minute or two and some are updated every 10 minutes (LTFT's). Also, some take 5 to 10 cycles and some take 20 cycles (start/drive/stop). The longest to take effect, as I recall are the LTFT's. There are 23 parameters in the PCM that relate to performance. Been a couple of years since I last looked at that info, but I believe it is correct. Best way to measure the relearn is to run a 20 minute test/scan run.
Old Jan 5, 2006 | 06:19 PM
BuffC5's Avatar
BuffC5
Reset the ECU to make sure.
Old Jan 5, 2006 | 08:00 PM
Mike Mercury's Avatar
Mike Mercury
hmmmm.. I thought the WOT tables were static ???
To PCM Learning
